Hey guyz, just bought a r33 a few weeks ago and loving it.
i just dont like the way the front looks.
the front looks like its higher than the rear.
i can stick 1 finger between the rear tyre and gaurd.
the front i can stick 3 fingers (like a whore).
anyone know why?
i am not liking the looks.
anything easy i can do?
i have attached some pics. will take some of the coilover so someone can try and figure out for me if they are adjustable ones.
cheers.
love u all
vish.
Rear tyre (nice)
front (not so nice)
Yeh except final cost would be around $2000 considering freight to get it from PERTH to Sydney...
Vish any suspension shop will be able to compress your springs mate, but that's actually just how the car sits. The rear guard is lower than the front, same as on a Statesman if you've seen em... Back tyres are half covered by the guards, but front tyres are clearly visible (not as extreme in your case obviously). If you draw a straight line between the rear guard and the front guard you will see what i'm talking about
lol TURBZ, as hanaldo sed i am in Perth.
Thanx for the info Martin.
Now i feel better, since u sed its normal. hahaha
I never knew that the rear gaurd was lower.
yeah maybe i will just take it to a suspension place and lower the front.
Thank you for the replies guyz :)
Yeh when they compress springs they just put a spring compressor clamp on them instead of physically cutting them.
Your best option (if you don't want to go all out with coilover suspension), would be to replace the springs with lowered king springs. Not that much more expensive than chopping or compressing, but definitely a better option.
You probably want to get your springs reset, which I guess is what people mean when they say "compressing".
http://autospeed.com.au/cms/title_Resettin...82/article.html
Changing the front height may well affect handling in a negative way if you go too far.
what bout what Martin said? replace with king springs. will that affect handling? dont want it too low. just the same height as the back so it looks level.
Does affect handling but in a good way. Stiffer springs = less body roll and better handling. As said, you don't want to lower the front too much, but a little bit shouldn't make a difference.
I'd have a chat with a good Suspension firm there in Perth and get them to do an initial evaluation including checking over what you already have > then commit to King Springs or at the time talk to Just Jap and/or others there in Perth about possibly replacing the springs with Tanabe brand or other instead. I find that Tanabe progressive springs are very good on my car as well as lowering the car by 20mm.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
