Hey guys,
My rear wheel bearings for my r32 Gtr need replacing.
2 questions.
1. Does anyone know where i can get competitive prices for these bearings?
2. Are they the same as r33 Gtr bearings, I found some online for about $250 each.
Thanks!
https://www.sau.com.au/forums/topic/317882-r32-gtr-rear-wheel-bearings/
Hi there. If you take the bearings to a bearing supplier they will cross reference the No's This will be the cheapest way and you will probably end up with the same bearings but not in a nissan box, and half the cost. P.S Just make sure its not only your tyres making the noise. Cheers
They rear wheels bearings are not generic so you wont be able to do that (the outer housing is a custom shape and AFAICT you cant remove the insides)
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
