Ok guys had an issue where jumper leads were placed on my gtr the wrong way round...
blew the power fc up.
melted a wire pretty bad at the positive terminal, replaced
now the power fc has been repaired and it seems all the settings and tune are still in the ecu, but now the car will just not run smooth through the rev range. it will idle but as soon as you try and rev through the rev range it just misses and is undrivable.
changed plugs
coilpacks
ignitor
i will be spending the morning diagnosing but if someone has any suggestions or has had this happen before i would love to hear them.
car is a r32 gtr/ to4z all the goodies
thankyou
https://www.sau.com.au/forums/topic/317916-bad-miss-after-short-circuit/
is there any chance that you might of knocked a inter-cooler pipe off and now have an air leak?? are you able to check the simple things like if your getting a good steady voltage and the afr's? maybe try swapping afms or swapping power fc's with someone else and sticking in your tune?
ok just pulled the power fc out and put the standard ecu in.. revs freely through the rev range
plug the power fc in and back to lumpy/missing running throughout the rev range
sensor check has ecc
if it drives good with the standard ecu in then maybe the power fc is f**ked
i wouldnt conclude that all tho it is a possibility, the standard ecu can run on less power and voltage, and can generally keep things running when somethings not working right.. whereas the car will play up with the power fc.. i had a melted wire in my car and was causing my tacho to play up with the power fc, but would run fine with the standard ecu.. post a help section in ur local state thread for someone with a power fc and datalogit.. so you can switch power fcs n tunes..
i wouldnt conclude that all tho it is a possibility, the standard ecu can run on less power and voltage, and can generally keep things running when somethings not working right.. whereas the car will play up with the power fc...
Does the stock ECU have a power save mode like my laptop? Lol....
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
