hey wats up ppl...is there something wrong with my ECU settings, like HICAs maybe? cos every time the road is dumb/wet my R33 GTS would go side ways from the lights in straight line mind u i'm not evening puting my foot down and if i put the foot wen its doing 60kmp it would not stay straight my qestion is.....WHY WHY WHY WHY WHY WHY WHY WHY??????
Edited by Mr366
https://www.sau.com.au/forums/topic/317925-skits/
I am still wondering what the topic and sub topic mean????
anyway....start with taking the car for a suspension check and wheel alignment. You might have either something lose or heaps of toe out. Maybe chuck $14 at pedders and see what they come up with.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197336
How about "skits" = "skids"?
NFI what "swining" is about.
WTF has happened to the english language?
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197914
HICAS starts kicking in above 60kph. If your hicas steering sensor is mis-aligned to the steering rack, you'll find the steering wheel will slowly 'roll over' above 60kph (and will snap straight at 110kph when HICAS turns off).
I could imagine, depending on how badly it was mis-aligned that it could get a bit dangerous in the wet. Certainly the 'snapping straight' at 110kph as it turns off can be dangerous even in the dry.
If you think this sounds consistent with what you're seeing, you can take the car to Nissan to get them to use CONSULT to check the HICAS - they can check the steering angle sensors vs the steering rack and should be able to re-align it. Alternatively, you could just use a HICAS lock bar - though in some states you may run into problems with this without it being an engineered modification.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5199113
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
