hey wats up ppl...is there something wrong with my ECU settings, like HICAs maybe? cos every time the road is dumb/wet my R33 GTS would go side ways from the lights in straight line mind u i'm not evening puting my foot down and if i put the foot wen its doing 60kmp it would not stay straight my qestion is.....WHY WHY WHY WHY WHY WHY WHY WHY??????
Edited by Mr366
https://www.sau.com.au/forums/topic/317925-skits/
I am still wondering what the topic and sub topic mean????
anyway....start with taking the car for a suspension check and wheel alignment. You might have either something lose or heaps of toe out. Maybe chuck $14 at pedders and see what they come up with.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197336
How about "skits" = "skids"?
NFI what "swining" is about.
WTF has happened to the english language?
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197914
HICAS starts kicking in above 60kph. If your hicas steering sensor is mis-aligned to the steering rack, you'll find the steering wheel will slowly 'roll over' above 60kph (and will snap straight at 110kph when HICAS turns off).
I could imagine, depending on how badly it was mis-aligned that it could get a bit dangerous in the wet. Certainly the 'snapping straight' at 110kph as it turns off can be dangerous even in the dry.
If you think this sounds consistent with what you're seeing, you can take the car to Nissan to get them to use CONSULT to check the HICAS - they can check the steering angle sensors vs the steering rack and should be able to re-align it. Alternatively, you could just use a HICAS lock bar - though in some states you may run into problems with this without it being an engineered modification.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5199113
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
