Dumb Question
2lazy
 Share
Hi,
I have searched but couldn't find a straight answer.
when a rd26dett us pushing 1bar at the manifold does that mean that each turbo is making 0.5bar or
each turbo is making 1bar per 3 cylinders which gives 1bar total at the manifold? :)
The real question is, if you run a turbo + supercharge setup, what will the boost be :P
Forgot to say too, it isn't so much about how much boost the turbos make, it is more about how hard they WORK to make that. All things being equal, 2 turbos will only have roughly half as much work done on them to make the same boost, since the air FLOW is higher even though boost is the same.
Edited by Thelen
^^^ well if the super is receiving air from the turbo it will be compressing compressed and pressurised air therefore e.g 2.5psia from the turbo compressor outlet into super inlet will give 5psia.... It would be like compound turbocharging, 40psi anyone?
If the super and turbo are receiving atmosphere air then if both run 12psi then manifold pressure should be 12psi??? not too sure on this one.
Edit: Let me make sure that im perfectly clear on this subject, if my sr20det made 200rwk at 1bar from a t28 will that mean that two t28's will make 400rwk at 1bar total?
Edited by 2lazy
manifold prussure, is exactly that, pressure in the manifold, or what we call "boost" when its past positive pressure or absolute pressure
where the pressure comes from is irrelevant, ie 1 turbo, 2 turbos, 3 turbos, supercharger and turbocharger etc
and pressure does not equal volume
this why 15psi on a stock turbo vs 15psi on a GT35R make different levels of power
I understand that but on that link there are two arguments, one is that:-
two turbos making both 1bar will make half has much air as one turbo making 1bar(same turbo model as the twin), so they flow the same both twin or single. You will see 1bar on your boost gauge with both set ups but they make ruffly the same amount of hp.
The other argument:-
twin turbos both at 1bar will make 1bar of pressure at the manifold BUT it will flow twice as much air.
You need to remember boost is a measure of restriction to air flow.
Keep everything at the same efficiency, increase air flow, boost will increase...
Hence two turbos at one bar combined flow as much air as one turbo at 1bar, making the same power...
Exactly, boost is a measure of restriction. It means the turbo(s) are pushing that much air, that the engine can't keep up taking it all in so it builds up and increases in pressure. (Think of blowing up a balloon). It is all about volume of airflow! Turbo(s) technically do not create "boost", they create heaps of airflow that as a result of being in an engine environment ends up being pressurised which is what we call "boost". Hence if you pop an intercooler pipe, no restriction, no boost in the intercooler pipes (theres a lot more that comes into play here but in general that's an easy way to think about it).
Edited by PM-R33
That is the best way I've heard someone describe it and should assist people in understanding.
pressure is constant but the flow/ volume of air doubles
not exactly. the possible volume of air doubles (free air delivery). once you put them into an enclosed system such as they are on an engine, and have the boost regulated by a wastegate measuring pressure (aka resistance), then you won't get double the airflow. your total airflow won't really change much because the things that are causing the restriction will still cause the same level of restriction whether you compress the air via 1 million mice blowing through straws or the worlds biggest turbo. there is a limit to how much extra air you can flow through the intake before you are going to hit the same restriction and i would guess that it isn't much more than with anything else.
"but people make more power with bigger turbos at the same pressure" is a common reply to that line of thinking, and i understand that, but how much of that is down to the bigger compressor on the turbo and how much is down to the fact that the exhaust flow is much higher and there is much less restriction on the exhaust side of the turbo? i'd say that a fair bit is on the exhaust side and not that much has to do with the bigger compressor (not saying that it doesn't play any part in it, but just not as much as people think).
 Share
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
    • the boost controller allows you to adjust the opening of the wastegate (which only has one preset spring) I'm going to see how it acts on it
    • I studied the principle of wastegate to begin with. so if I understood correctly. the moment when the turbo "spool" is where the boost control begins. When the target level of "psi" is reached the wastegate opens to regulate the exhaust pressure passing through the turbo and thus control its speed and the rate of boost
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
