Here's one of the threads about it:
http://www.skylinesaustralia.com/forums/Gt...turbo+boost+add
Any logical person that knows a bit about physics realises that each pressure can not combine the way people are thinking.
Edited by PM-R33
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5198703
The real question is, if you run a turbo + supercharge setup, what will the boost be :P
Forgot to say too, it isn't so much about how much boost the turbos make, it is more about how hard they WORK to make that. All things being equal, 2 turbos will only have roughly half as much work done on them to make the same boost, since the air FLOW is higher even though boost is the same.
Edited by Thelen
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199336
^^^ well if the super is receiving air from the turbo it will be compressing compressed and pressurised air therefore e.g 2.5psia from the turbo compressor outlet into super inlet will give 5psia.... It would be like compound turbocharging, 40psi anyone?
If the super and turbo are receiving atmosphere air then if both run 12psi then manifold pressure should be 12psi??? not too sure on this one.
Edit: Let me make sure that im perfectly clear on this subject, if my sr20det made 200rwk at 1bar from a t28 will that mean that two t28's will make 400rwk at 1bar total?
Edited by 2lazy
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199371
manifold prussure, is exactly that, pressure in the manifold, or what we call "boost" when its past positive pressure or absolute pressure
where the pressure comes from is irrelevant, ie 1 turbo, 2 turbos, 3 turbos, supercharger and turbocharger etc
and pressure does not equal volume
this why 15psi on a stock turbo vs 15psi on a GT35R make different levels of power
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199637
I understand that but on that link there are two arguments, one is that:-
two turbos making both 1bar will make half has much air as one turbo making 1bar(same turbo model as the twin), so they flow the same both twin or single. You will see 1bar on your boost gauge with both set ups but they make ruffly the same amount of hp.
The other argument:-
twin turbos both at 1bar will make 1bar of pressure at the manifold BUT it will flow twice as much air.
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199664
You need to remember boost is a measure of restriction to air flow.
Keep everything at the same efficiency, increase air flow, boost will increase...
Hence two turbos at one bar combined flow as much air as one turbo at 1bar, making the same power...
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199675
Exactly, boost is a measure of restriction. It means the turbo(s) are pushing that much air, that the engine can't keep up taking it all in so it builds up and increases in pressure. (Think of blowing up a balloon). It is all about volume of airflow! Turbo(s) technically do not create "boost", they create heaps of airflow that as a result of being in an engine environment ends up being pressurised which is what we call "boost". Hence if you pop an intercooler pipe, no restriction, no boost in the intercooler pipes (theres a lot more that comes into play here but in general that's an easy way to think about it).
Edited by PM-R33
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199731
That is the best way I've heard someone describe it and should assist people in understanding.
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5199836
pressure is constant but the flow/ volume of air doubles
not exactly. the possible volume of air doubles (free air delivery). once you put them into an enclosed system such as they are on an engine, and have the boost regulated by a wastegate measuring pressure (aka resistance), then you won't get double the airflow. your total airflow won't really change much because the things that are causing the restriction will still cause the same level of restriction whether you compress the air via 1 million mice blowing through straws or the worlds biggest turbo. there is a limit to how much extra air you can flow through the intake before you are going to hit the same restriction and i would guess that it isn't much more than with anything else.
"but people make more power with bigger turbos at the same pressure" is a common reply to that line of thinking, and i understand that, but how much of that is down to the bigger compressor on the turbo and how much is down to the fact that the exhaust flow is much higher and there is much less restriction on the exhaust side of the turbo? i'd say that a fair bit is on the exhaust side and not that much has to do with the bigger compressor (not saying that it doesn't play any part in it, but just not as much as people think).
https://www.sau.com.au/forums/topic/317943-dumb-question/#findComment-5207296
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
