Y'day after work went to start my car after is had been sitting for 8 hours, I turned the key it started but is strugled to build revs to idle (900rpm) the rpm's went up in stages 200rpm 500rpm then finally when i touched the accelarater it went up to 900rpm? i thought oil pressure? or something to do with cold start?
the only thing i touched was the afm all i did to that was make sure the plug was in properly
i have another question aswell, i think my afm is playing up my car just doesn't feel the same since last fri nite when i had a major boost cut, it was like a hit a wall then i took my foot off the accelerater abit it started to boost again! now it feels different, could it be in some kind of limp mode? it still revs past 3000rpm just feels a bit slower
is there a way to check the afm is working 100%? with afm do they either work or not work? or can they still work at only 50% if that make sense
thanks
if stock ecu, get nissan consult (cable and software) you can buy it, check for NewKleer (he makes them) on the forums
then check the stock ecu diagnostics via the software it will tell you if the AFM is toast
if AFM is toast - ie completely dead REV is capped at 2500rpm
but if its dirty / mangled it may work enough to run, but make fuel injection run like ass, ie botched airflow vs real airflow
check its plug, check for damage, visual inspection, check with elec/carby cleaner
Do a search, from what you are saying the airflow meter has dry solder joints inside on the board. There is a how to for repair if you do a search. As a temp solution you could possibly cable-tie the wires down tight one way or the other but it needs to be fixed or replaced.
have you put diffrent fuel in latley???
sounds like it is fueling up.. could be your afm or your fpr......
if its a stock ecu, do a reset and put it in learn mode....
to reset Take the terminals off the battery, then turn the lights on to get rid of stored power.....
put back together and turn the key... it will be in learn mode for 30 key turns... if it was your fuel it will sort it self out.... if its ur afm, clean and replace if you have tooo...
good luck
also check your plugs.... could have givven you the wall hitting experience.. and be down on power..
thanks muff i will try anything is there a way to check voltage with a multimeter for the afm?
im waiting on new coil packs i will check and change plugs when i get the new coils
and for the fuel i use the same fuel from the same place everytime i fill up
  • 3 months later...
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
