  • Replies 191
Posted Images
Wow some big discrepancies there...!
4.6 with 170rwkw (albeit in a 32 which is lighter) and only 5.75 with 265rwkw in a 34?
A much heavier less powerful XR6T can easily do low 5s... I guess it all comes down to wheelspin in the skyline then...?
What is the best way to get a 34 to hold traction? Suspension, tyres?
I think i'll be running my rears down around 20psi when i get it back...
Soft spring rates, pineapples bushes set to maximum squat, zero negative camber or 1 degree postive camber if the car squats a lot (as it squats it will gain negative camber which in turn will return it to around zero), good tyres, not to low. With a setup like this (probably similar to what Paul had) is your best way for a good time. The problem is most of us know this, but don't actually do it and have low cars with aftermarket coilovers and average tyres :)
Well I can get my tyres 0 - 100 in around 2 seconds... Unfortunately the car itself takes a fair bit longer...
Even if I pull a perfect launch, I have a major issue of grabbing second and the car fries both rears... That's with 255 wide rears... And it also does it on semis...
an extra diff :)
Sorry, had to say it :(
I was actually planning on selling the GTT and getting a 34 GTR - was for sale for several months but there was no way I was getting what I wanted for it... and the changeover price for a good low km fairly stock 34 GTR was going to be well over 30 grand...
Got advised by many people that it wasn't worth it, and that I wouldn't be satisfied with a stock GTR anyway. Then to modify it would cost twice as much as the GTT etc etc...
Decided to stick with the GTT and do turbo etc so i guess i'll see what it's like at the end of the week when i get it back! Not like I'll probably ever have the chance to drive a 34 GTR to compare so I guess it probably doesn't matter!
I went the larger .82 housing on the 3070 hoping the boost response would be a bit more linear, and less likely to fry the tyres when it came on compared to the .63... Hopefully I was right... :P
I went the larger .82 housing on the 3070 hoping the boost response would be a bit more linear, and less likely to fry the tyres when it came on compared to the .63... Hopefully I was right... :)
I have a 32 GT-R and i love it to bits but some things you can only really enjoy in RWD :P
Plus the 34Gtt's are pretty sexy there are a few getting round here in bris that a sick !
Edited by Nee-san
Those claimed 0-100 times for the xr6t would have been done by professionals who know how to launch that particular car when it was in testing, not your average joe. They also have a launch control system in them as well...
Yes, tyres and suspension play a fairly big role when it comes to launching, but it mainly comes down to the driver.
You did choose right, the power is quite linear, when i had my 3076 it was a lot easier to get the power down than when i had a apexi ax53b70 p25 because the apexi was so responsive it would just fry tyres the second you applied throttle
The best i have done so far is a around 5.8, thats with 236 rwkw's and zero traction. The main prob is traction. I have been beating by a mates standard wrx because i had no traction through 1st or 2nd. I know have semi slicks but haven't tried them out yet.
I'd say mid 4's if you are running decent rubber.
if you are struggling for traction consider
wider tyres - as wide as you can run cost effectively without scrubbing
better tyres - cost = more grip usually, pzeros are ace, my best 0 too 100 was with them
less pressure - 20psi for max grip - 40psi for normal drive and good economy
pineapple / diff cradle kit - prevent tramping on the diff / hopping
camber (make the wheels sit flat when you dump power, most will find inwards, reducing contact area)
tune the boost curve to give best boost vs traction - ie AVCR with gearjudge
I guess you could always try not putting your foot to the floor in the 250kw+ Skyline and feeding it in..? Guess that can be a hard ask in the heat of the moment. Will have to see how i go next weekend i suppose...!
I don't want to get beaten by a fairly standard skyline (or a bloody WRX) after spending the amount I just have for 250-300kw so i might just get some damn good tyres...! :P
I guess your usual inner-city drag doesn't start off with a full on launch though anyway, it's usually the feel each other out through the first half of first, then once you both know you are going to go put the power down... Am I right to assume that in that situation the 250-300kw Skyline is going to leave the 200kw one, or the SS / XR8 / WRX in the dust (obviously that is then taking the launch out of it...)?
^ LOL
So 20psi in street tyres is about the best for traction? Might give it a try.
Hahaha yeah obviously. Might try them at 20psi and have a bit of practice launching to see how they hold up.
hey mate
20psi does indeed give noticably better traction but it's more for straight line stuff
just be careful in particular with running taller profile tyres at that pressure, especially if you plan to corner hard/kick the back-end out..
when I was younger I was a passenger in a VN SS running low rear tyre pressures for grip and the tyre rolled off the rim. wasn't pretty.
cheers,
-dave
Yeah definitely wouldn't be taking any high G corners with 20psi in them :P Like I said, wouldn't mind doing a bit of practice with launching. Definetely want to start getting the power down a lot better and earlier so semi slicks will definetely be on the agenda once mine are worn down.
Edited by PM-R33
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
