  • Replies 191
Posted Images
Wow some big discrepancies there...!
4.6 with 170rwkw (albeit in a 32 which is lighter) and only 5.75 with 265rwkw in a 34?
A much heavier less powerful XR6T can easily do low 5s... I guess it all comes down to wheelspin in the skyline then...?
What is the best way to get a 34 to hold traction? Suspension, tyres?
I think i'll be running my rears down around 20psi when i get it back...
Soft spring rates, pineapples bushes set to maximum squat, zero negative camber or 1 degree postive camber if the car squats a lot (as it squats it will gain negative camber which in turn will return it to around zero), good tyres, not to low. With a setup like this (probably similar to what Paul had) is your best way for a good time. The problem is most of us know this, but don't actually do it and have low cars with aftermarket coilovers and average tyres :)
Well I can get my tyres 0 - 100 in around 2 seconds... Unfortunately the car itself takes a fair bit longer...
Even if I pull a perfect launch, I have a major issue of grabbing second and the car fries both rears... That's with 255 wide rears... And it also does it on semis...
an extra diff :)
Sorry, had to say it :(
I was actually planning on selling the GTT and getting a 34 GTR - was for sale for several months but there was no way I was getting what I wanted for it... and the changeover price for a good low km fairly stock 34 GTR was going to be well over 30 grand...
Got advised by many people that it wasn't worth it, and that I wouldn't be satisfied with a stock GTR anyway. Then to modify it would cost twice as much as the GTT etc etc...
Decided to stick with the GTT and do turbo etc so i guess i'll see what it's like at the end of the week when i get it back! Not like I'll probably ever have the chance to drive a 34 GTR to compare so I guess it probably doesn't matter!
I went the larger .82 housing on the 3070 hoping the boost response would be a bit more linear, and less likely to fry the tyres when it came on compared to the .63... Hopefully I was right... :P
I went the larger .82 housing on the 3070 hoping the boost response would be a bit more linear, and less likely to fry the tyres when it came on compared to the .63... Hopefully I was right... :)
I have a 32 GT-R and i love it to bits but some things you can only really enjoy in RWD :P
Plus the 34Gtt's are pretty sexy there are a few getting round here in bris that a sick !
Edited by Nee-san
Those claimed 0-100 times for the xr6t would have been done by professionals who know how to launch that particular car when it was in testing, not your average joe. They also have a launch control system in them as well...
Yes, tyres and suspension play a fairly big role when it comes to launching, but it mainly comes down to the driver.
You did choose right, the power is quite linear, when i had my 3076 it was a lot easier to get the power down than when i had a apexi ax53b70 p25 because the apexi was so responsive it would just fry tyres the second you applied throttle
The best i have done so far is a around 5.8, thats with 236 rwkw's and zero traction. The main prob is traction. I have been beating by a mates standard wrx because i had no traction through 1st or 2nd. I know have semi slicks but haven't tried them out yet.
I'd say mid 4's if you are running decent rubber.
if you are struggling for traction consider
wider tyres - as wide as you can run cost effectively without scrubbing
better tyres - cost = more grip usually, pzeros are ace, my best 0 too 100 was with them
less pressure - 20psi for max grip - 40psi for normal drive and good economy
pineapple / diff cradle kit - prevent tramping on the diff / hopping
camber (make the wheels sit flat when you dump power, most will find inwards, reducing contact area)
tune the boost curve to give best boost vs traction - ie AVCR with gearjudge
I guess you could always try not putting your foot to the floor in the 250kw+ Skyline and feeding it in..? Guess that can be a hard ask in the heat of the moment. Will have to see how i go next weekend i suppose...!
I don't want to get beaten by a fairly standard skyline (or a bloody WRX) after spending the amount I just have for 250-300kw so i might just get some damn good tyres...! :P
I guess your usual inner-city drag doesn't start off with a full on launch though anyway, it's usually the feel each other out through the first half of first, then once you both know you are going to go put the power down... Am I right to assume that in that situation the 250-300kw Skyline is going to leave the 200kw one, or the SS / XR8 / WRX in the dust (obviously that is then taking the launch out of it...)?
^ LOL
So 20psi in street tyres is about the best for traction? Might give it a try.
Hahaha yeah obviously. Might try them at 20psi and have a bit of practice launching to see how they hold up.
hey mate
20psi does indeed give noticably better traction but it's more for straight line stuff
just be careful in particular with running taller profile tyres at that pressure, especially if you plan to corner hard/kick the back-end out..
when I was younger I was a passenger in a VN SS running low rear tyre pressures for grip and the tyre rolled off the rim. wasn't pretty.
cheers,
-dave
Yeah definitely wouldn't be taking any high G corners with 20psi in them :P Like I said, wouldn't mind doing a bit of practice with launching. Definetely want to start getting the power down a lot better and earlier so semi slicks will definetely be on the agenda once mine are worn down.
Edited by PM-R33
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
