  • Replies 191
Posted Images
8k limiter and side step.... what is wheel spin?? ive never heard of it?
Lol. Yes, yes, GTRs are great - we've all heard it before. :thumbsup:
Like previously stated I was all for selling the GTT and getting a 34 GTR but they are just so overpriced still at 10 years old. I used to have a 32 Gtst and although a 32 GTR would be fun at $15-20k personally I feel they are just way too old for an every day driver - no offense of course!
This is really a thread about RWD Skylines and what is achievable in 0-100 times, essentially with 'cop friendly' launches, compared to the similar rivals ie WRX, STI, XR6T, SS etc etc
has anyone done back to back runs with 255/17s and 275+/18or19s with around 250+rwkw.. with similar tyres to see if the wider tyre on a bigger rim results in more traction??
I have roughly 440rwhp atm and trying to work out all the things i can do to improve traction and any handling improvements i can make without sacrificing traction... does anyone know if polyurethane bushes would decrease traction?
Cheers
Jarrod
an lsd helps alot!
depending on the condition of your stock lsd.
i had no traction 1st to 3rd (251rwkw) with stock lsd, put a nismo 2way and although i do still get some wheel spin, its nothing compare to before and the car is alot quicker...
Edited by Kaido_RR
one thing people have overlooked in this thread.
Suspension setup.
Stock suspension with pineapples pointing the pinion angle in the correct position will get you soo much more traction then a set of coil overs.
The difference is amazing.
On this topic of pineapples, can anyone share with us the best way to get the pineapples setup correctly for maximum traction? there are 3 ways you can setup the pineapples but which one is the best for drag traction? I am sure there is a thread on here about it from back around 2003 2004 when i got my pineapples but I cannot be farked searching for it at the moment. Maybe someone can find it and test it and post up their results for everyone to see?
Who is going to try it out?
Okay I decided to not be so lazy and found this.
My pineapples are currently setup for "all round performance"
http://www.whiteline.com.au/instruction/203a_KCA349.pdf
there you go :thumbsup: - also SHIM YOUR DIFF!
hi guilt toy
i dont know the best setup, but i had centreline setup the pineapple diff cradle package on my car and from memory its on drag launch setup and its never been changed from that. from their documentation drag launch is really maximum traction, from memory mine is on that. i have std shocks still
How much do these pineapples cost and where can i get them from? Will any suspension place know what I'm talking about if i go in? I still have standard shocks but slightly lower king springs - sounds like the pineapples might help me out a bit?
qwilkinson34, look at the link posted by Guilt-Toy in post #46. It specifies whiteline part number and explains them. Roughly $110.
I am getting some pineapples fitted today by Centreline suspension. I am getting quite a bit of axle tramp, Chris wants to fit them at all round performance. What do you guys think?
Has anyone tried them at both all round performance and maximum traction to give a comparison?
Edited by Harey
my car is setup by centreline with the pineapples for "all round"
greddy 6/8 coilovers, pineapples, superpro castor and camber bushes, selbys non adjustable swaybars, strutbraces and a mechanical 1.5 way diff.
i get zero tramp and very good traction.
i run the car @ 320mm centre to guard (low as) and with 245/40/18 nitto NT05's i get traction through all gears in the dry with 285rwkw
on e85 i am pushing 325rwkw and only just lose 1st but have all of 2nd, 3rd, 4th and 5th :happy:
What sort of 0-100 time do you think you can manage with that setup?
Are there any drawbacks to having these things installed on a daily driver...?
nope... have had mine in for over 2 years now
i have no idea actually.... would have to be pretty good tho (driver dependant) :happy:
Thanks mate! All round it is
I cant believe you can get traction in 1st gear with 285rwkw! Your car must be setup very well.
Hey mate, how do you find the nittos for street use ?
no worries ;)
Yeah Hamish, how the hell do you get traction in second, let alone first :)
My setup is similar to yours other than the 1.5 way.
nitto's man.... with the federals it was very very different
brilliant.... but expensive
have done 5000k's so far including 1 DECA and will definately see 10,000 above that it will depend on how many trackdays i get in :D
in the rain they are shit like all tyres, but not dangerous at all.... they still give much more traction than most :D
"RRP" is 480 in a 245/40/18
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
