Modified Skyline 0-100 Times
yeah but comparing a big single 3076 proper setup to twin GTR is a fairly different comparison
i vote for the 3076 setup on the GTR - 4wd, individual throttle bodies, lots of gearing
i think ANY car stock is fairly ordinary
the only stock car that has suprised me is a friends WRX here (non STI)
i think its maybe a 2004/2005 WRX, and it has tons of torque everywhere and its bone stock
it has more pull in every gear over my GTST with usual mods
  • Replies 191
Posted Images
Of course - but that's gonna cost you $30k more... :(
More pull than your car with 194rwkw? Really?
I've driven an (05 i think?) WRX with a big cooler, exhaust, intake etc (standard boost) and i didn't think it was any quicker than my 34 when it had 185rwkw...
It did have a more 'torquey' feel though, less revvy...
I have always liked WRXs - they sound awesome and handle a shitload better than skylines - but they are everywhere and I think the 34 just has 'something' that the WRX doesn't somehow...
yep my GTST which ive had for 7 years has exhaust, intercooler, aggressive tune, heavy duty clutch, pump, splitfires, good tyres, suspension work, camber, castor, all the other bits and 192rwkw
the wrx is non-sti bog stock and its got 62,000 on the clock, my gtst has 230,000 on it
even when i had my gtst with 100,000 i still think the WRX has a bit more pull
i dont know how it would go on the street against each other, but i can feel the wrx pull more
and this is on light cruise, full gear runs, up hils and bogging it down
ie 50km in 4th gear lots of lag and floor it in both cars
60km in 5th gear lots of lag and floor it
the wrx seems to pull more consisntently all the way through
its probably a bit unfair as the skyline has a lot of km's on it
but the skyline also has 10k worth of parts on it
yeah i should add the wrx feels like it will drop off quickly and the tacho redline starts at 6500rpm
the skyline seems to pull alll the way and not die off, but wrx pulls more
i dont know if its the 2L or 2.5L wrx, ill check
Fair enough. Must say the RB25 NEO I have is around 30rwkw and 50+nm better through the whole range until 5k than a non NEO with the exact same mods / tune (compared at Morpowa) so might have something to do with it... Newer engine in the Rexxy = better technology / flow than an R33.
Still surprising in a car that weighs the same and would struggle for 130-140rwkw (stock) vs 190+... Anyone got thoughts on this?
yeah not sure what it weighs or what power it has
and not sure if its the 2l or 2.5l, but either way it is 4 cylinder
so
wrx 2l = 500c per cyclinder
wrx 2.5l = 625 cc per cylinder
r33 2.5l = 415cc per cylinder
that might be why
so
that might be why
Surely more displacement per cylinder does not equal more torque...? It's a whole system as our 6 cylinders = 1 crank rotation in the same time as the 4 WRX cylinders do...?
dont know if its the be all and end-all but think of the EVO and the SR20
both are 2 litre 4 cylinders and pull some pretty good numbers and have good cc per cylinder vs other in line 6's
check out the barra XR6t
and we all know those things pull some spastic numbers
4l = 666cc per cylinder
if we follow the CC per cylinder rule for most torque
the lowest is the R32 GTST and the highest is the LS1/LS2's
and the 200sx, WRX, EVO and XR6 are in the mid to high end
the R32 GTST, R33 GTST, GTR are in the lower end
give us some more engine specs / mods and ill chart them all up
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
