Folks
I've got for sale a set of factory R33 gts-t wheels with roadworthy tyres. Good for skids, thats probably about it.
They've been sprayed gloss black, quite badly, and have been sitting in the back of the shed since 2006.
One of the wheels has very deep scratches across the face of the rim, but i drove around on it like that for years so id suggest that it is still structurally sound.
Can take pics for anyone interested.
$100 pick up from western suburbs of melbourne.
https://www.sau.com.au/forums/topic/317965-r33-wheels-and-tyres-100/
Ok mate well let me know what ya gonna do i just want they because im going to join the skyline club and it would be good to have them so i dont chew up my good tyres and rims on club days.
I'll pick them up tomorrow if you still have them(I'm in St. Albans).Just bought a R33 Gts-t this weekend and it has spacers on the front wheels.I need them to pass a RWC.Call me on 0422427369 if you still have them.Cheers
Ok, sorry everyone, slight mistake on my part. Two of the tyres are good and two of them are just on the markers and probably not roadworthy.
Pics are below. Excuse the four years worth of dust and spider webs :happy:
If anyone wants to pick them up, im free after 7pm any day this week. Preferably p.m. me and we'll organise a time otherwise msg to 0434 463 181 if you prefer.
  • 3 weeks later...
The semis are attached to 18" 350z wheels which I sprayed black.
The wheels + tyres will probably be for sale after next weekend, although I don't expect there to be much tread left. They're basically on the indicators as it is.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
