hi gangs...
long story short, having problem putting the rubber joiner back on for the manifold inlet, what do i need to do?seems to hard to push it back down and slip it in at the other end. any other way i can connect it back?? rubber too stiff or hard..!! picture below will tell u what i meant..btw, i was trying to change spark plugs before i got stock to this problem..car been out of road for a week now..anyone from westside gimmi a hand for a can of VB or something??
cheers guys..
https://www.sau.com.au/forums/topic/317966-need-help/
have you connected all other end clamps? if so undo them a little to allow for some movement. It should just slot back in unless everything else is locked tight, with a bit of a wiggle a bit of lube and a few choice words.
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197815
i havent put the hose clamps back on yet..not enough gap or space to wiggle the other end...not even enough space to push it down and slot back in.!! really frustrating me now!! i got it out easy at the first place but putting it back in is an asS thing to do!!!
anymore trick to slot it back in guys??
Edited by myRB25DETT
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197825
what do you mean by not enough room to push it back down and slot it in, Try completley disconnecting the other end of the pipe so you have more movement to push it on then connect the other end when the throttle body end is on....where bouts are you?
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197868
sorry mate but the only way to get it on is to persevere at it and have plenty of patience. i always have trouble with my piping yet i eventually get it back on. Im missing a couple fingers off my main hand and i can do it.
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197883
well as u could see on the photo,i got the left side out, but the other end i couldnt, no way i could disconnect completely at the other end..pretty much dead end...i live in altona..next to altona beach or altona station...
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197938
There is no real "trick", just have to make it go in :blink:
Sometimes a tiny bit of oil around the inside edge can help
i know what u mean, but thats not even close to my case, my hose is not even facing evenly with the other end/inlet that you can just lube it and slot it back in...hose is slightly few m.m. above the inlet manifold and tried pushing it down to face the inlet and so i can just slip it thru but thats where the problem is, cant push it down far to face the inlet and then in...argggg
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197953
In your OTHER thread, it seemed to be all connected.
Oh well then, PM me your address and I'll come to you.
sorry to confuse u, but nah its not connected, and yeah thanks heaps for the offer....PMed u already for the add...let me know what i owe u!! :blink: cheers for that!!
https://www.sau.com.au/forums/topic/317966-need-help/#findComment-5197969
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
