Hi all,
Can anyone please confirm when hi beams are switched on, the low beam headlights should also remain on?
This is what the mechanic reckons as I have just gone for a pink slip test and did not pass because of this.
From memory I have never seen happen on my R33 GTS-t but haven't really took too much notice.
Cheers,
Leo
Edited by gwholxc
https://www.sau.com.au/forums/topic/317977-help-regarding-headlights-for-r33/
Hi all,
Cheers,
Leo
The low beams turn off when you put high beams on as standard. I would find a different mechanic...
If you try and hold the stalk between the low beam and high positions can get them working at the same time though :blink:
Legaly your mechanic is correct. Skyline headlights don't do this and most people couldn't give two shits so just find a different mechanic.
affirmative. almost all cars that you see will have both highs and lows on at the same time. r33s all have what you do. there is a mod you can do, and its in the DIY section to fix this.
I only noticed it as something out of the ordinary when I got my Subaru, low beams are always on!
I wonder what reasoning behind the rule is... as the high beams ALWAYS come on before the low beams turn off so you always have continuous forward facing light and the low beams are quite redundant while the high beams are on :blush:
Makes sense for the low beam to stay on when turning on high beam if you've got xenons... it's not good for the xenon bulb to be turned on and off quickly. But otherwise agree if they're just standard halogens the low beam is made redundant
I'll check out the DIY section; I've wanted to have this done since buying series 3 headlights aftermarket.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
