*SOLD* *SOLD*
Set of bronze coloured Rays Nismo LM-GT4's. Size is 18x10.5 and offset is + 15.
Wheels are about 2 months old and have a scratch as pictured. It is not deep (not gutter rash or anything), just a very small paint scractch which happened when the wheels were being fitted with tyres.
Wheels do not come with tyres.
Asking price is $3k. These wheels be da bomb!!!
user posted image
user posted image
user posted image
Silver LM-GT4's on R34 GTR:
user posted image
user posted image
user posted image
:headspin:
https://www.sau.com.au/forums/topic/31799-fs-nismo-lm-gt4-18-x-105-suit-gtr/
If these had come up a few days ago they would be in my garage now, not that BBS ones I got are bad but they are VERY nice. You are local too! That makes it even worse. Whoever gets these is very lucky indeed.
10.5 inches will fit under R33 and R34 Guards no problems with that offset if the car isn't lowered. If it is lowered, it'll sometimes rub on the inner guard liner at full lock, especially if you're on a hill or going up a driveway or something that makes the suspension compress a little more.
The main reason is that I want Silver ones, not Bronze ones though :)
Don't worry, these babies would make anything look good!
One tip for the lucky one that can afford them......... "Insurance"
I reckon bronze on midnight purple looks awesome like Jamezilla's car!!!! How about 19 inch te37s in silver!!!(drooool)
  • 3 weeks later...
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
