just did a suspension swap put in some tein super streets. unfortunately the car is jacked up like a mofo.
being a poor sucka atm, i didnt want to fork out $80 for a set of tein c spanners, so i got some generic c spanners from a bike shop. they kind of fit.
unfortunately I've quickly come to realise they werent good enough. my hand just kept slipping which resulted me punching my car countless times and bruised and bloody knuckles.
Anyways, i think i've done my fair share of swaring and punch. can anyone in sydney let me borrow some c spanners PLEAAAASSEEE! this is killin me.
i've tried the hammer and screwdriver trick too, its damaging the rings without much movement at all!
https://www.sau.com.au/forums/topic/318028-help-a-brother-out/
I don't have a set of c spanners around...but some suggestions:
Thoroughly clean the thread below the spring seat of any grit. Degreaser and a nylon brush should do the trick
Once it is clean you only need to move the bottom ring about 1/8 of a turn and it should spin freely on the thread. So the c spanner are only really needed for the initial loosening and then tightening again at the end. The top ring should turn freely down until it starts to lock onto the lower ring again.
If hammer and screwdriver won't dislodge it a c spanner wont be much good either :blush:
Brothels need all the help they can get too... But Help me first :blush:
thanks for the tips, I've been using wd40 on the threads. I'm able to dislodge the bottom ring and likenu sad it springs freely by hand. It's The top one I find the most issues with. Can't fkn move it at all, i think it's cos of the spilrng tension pushing down on the ring?
sorry....i assumed!
you should put a coil spring compressor on it first to take the tension off. For sure it will be a bastard of a job with the spring pushing on it!
about $20 at super cheap
spring compressor activated... it at least moves a little bit, but it is SO rediculously hard to turn. Do others have teins and can you tell me about ur experience? surely they couldnt have designed something so shit that you need spring compressors and still barely adjust!!! or am i doing something wrong
i was able to lower the rears, but the front is now killin my like cos there is hardly any space for compressors to go in... (and i dont think i lowered the rears enough =( F(@*@*#&@*!!!) have to go thru that shit again!
okay... adjustments done. some nice person let me use their Tein C spanners.
valuable lesson learned - dont be a fkn tightass when it comes to specialised tools!!!! just pay for it and it will save you hrs of stuffing around and possibly reduce injuries.
The End
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
