Recently purchased a GCG r33 high flow which appears in good condition. Before i installed it i changed the wastegate to a rb20(10psi) wastegate. The original wastegate on it was an original 7psi one.Then went ahead on a straight foraward install with mechanic supervison and support.
My r33 gtst was running 190kw on 12 psi with stock turbo, pfc, 3inch exhaust, smic, , 040 fuel pump, profec b greedy boost controler, standard air box.
After install:
When i installed the gcg high flow, car started fine and then i took it for drive around the block. When the car came on boost it whistled loudly then the car hesitated and stalled. Got it started but it idled poor and was blowing white smoke when i reved it. it did not allow me to rev it. Manged to get it home home and then took all the plumbing off to inspect compressor wheel as i suspected a blown turbo. Lucky for me everything was good and wheel was still on the turbo.
I took of the rb 20 wastegate off and installed the original r33 wastegate which is the same as my stock turbo. Started the car and took it for a drive. This time i drove it on 7psi stock boost of wastegate and not 10psi(rb20). The car ran well however it has a small miss in the low rev ranges.
I have z32 airflow meter, injectors and retune planned for next month
Is this normal behaviour for an untuned turbo upgrade?
What are your thoughts on this
please help.
Winding up the boost on a stock r33 gts-t is whats going wrong. They don't mind carrying on even with small psi increases, as far as I know Nissan did this to discourage modifying by making it harder than just winding boost up. Gone are the R32 gts-t days where you could wind them up to 16psi with a decent intercooler and exhaust, providing the turbine wheel didn't spit out off first.
Whistling/stalling was probably an air leak, and you would expect black smoke in that case. White smoke is burning oil, which could mean the turbos bearing seal is stuffed, which probably means the bearing is stuffed. Does the wheel turn smoothly? Is it still burning oil (because changing the wastegate actuator shouldnt have any impact). If its stopped burning oil i have NFI
Thanks for advice guys, problem has been fixed.
1. Hose between throttle body and intake pipe was leaking air.
2. irridium plugs were fouled so i cleaned them with prepsol and gapped them to .8
Car runs perfect on 7psi with gcg turbo and pfc current tune. it appears that the car can only handle 7psi on current tune as anything hire than this will foul the plugs.
That doesn't make sense.
you did change the oil supply line to the turbo to a non standard one or modify the stock one by drilling out ALL the oil restrictors in the bangos and bolts?
if not the whissle was the comp wheel eating the comp cover because the thust bearing has failed fom not enough oil
Why do i need to modify oil lines if im only replacing my stock r33 turbo with a gcg high flow. Both turbos look the same and all lines bolt up perfectly. The gcg turbo has different internals and new ball bearing cartridge. It is a direct bolt on fit.
Anyway we dont need to continue the thread cause the car runs perfect, all problems have been sorted, thanks guys.
He doesn't need to modify the oil lines, he is replacing a BB with a BB, they still need to be restricted. If he removed any restrictions he would blow the turbo seal big time. Different if he was changing over to a PB turbo.
I thought the rule of thumb was that that Thrust/Journal Bearing cores needed a more oil where as Ball bearings only need a small amount?
When i put my hybrid j/bearing turbo on, I had the guy drill out the stock banjos and lines.
  • 2 years later...
This is 100% a vacuum/ boost leak, i just installed a GCG highflow myself, and forgot to tighten up on of the intercooler hoses properly. as soon as it was under load it popped off and behaved exactly as the car in this thread. I put the hose back on and tightned her up... no worries mate!
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
