  • Replies 59
Posted Images
i will be very keen on these if i can sell some of the stuff i have for sale on here...
or if ur keen on partial trade for some of my items,
if u have an rb26 that is :-)
cheers
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5198827
for those wondering the r35 has the same setup as z32 brakes and the handbrake is drum setup
The same set up as Z32? So therefore the same as R33? So no special brackets would be needed?
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5199963
For sale is a set of 4 cailpers from a r35 gtr.
here is an example of custom caliper adapters mounts should look like to use on a R32/Z32/S15
spindle.
Price : $2700
You've got pm Working out how to fit them onto a GTR33 track car I am building ATM
cheers
Alex. Mordialloc 3195 0433 878905 www.jds-auto-imports.com
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5200771
victoria/melbourne
Hi, pm you, but no reply yet. Do you have the front and rear rotors and heads, I have got TE37 18x10.5 which will clear the 380mm rotors and carlibres. I am in Melb and would like to meet up with you
Alex 0433 878905
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5202828
victoria/melbourne
Hi kon please ring me 0412351418
regarding payement sent pm regarding location can deliver money cash to you
I have friends at deer park . Let me know thanks bill
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5203882
nothing fishy dude i am racer986jec if u go to xe.com u'll see the cailpers are advertised for 2.5K usd which is $2700 aus which is wat i got them advertised here, and for anyones information they'l be coming from japan and not the states, reason i got them advertised here is so i dont hav to pay paypal fee's but if anyone feels more safer, goin thru paypal they can if their willing to pay fees!
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5205316
for some reason this forum will only let me reply to PM's 1 every hour, so if u hav any questions email me at [email protected] and u'l get a much quicker response, cailpers are stil up for sale no1 has left a deposit
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5205348
So these are with you in Australia or still in Japan?
https://www.sau.com.au/forums/topic/318050-r35-gtr-brembos/#findComment-5205665
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
