heya guys,
i was just wondering if anyone would be able to upload a picture of there r32 gtst bonnet latch? as i would like to put a gtst front back on my car but has a gtr front bar on atm and i think the latch has been cut and lengthend and welded and just wanting to see what a standard one looks like
thanks mark
https://www.sau.com.au/forums/topic/318090-r32-front/
    • Holy hell! That is absolutely stunning! Great work!!!
