Oh yeah, I have. It wasn't anything too serious fortunately. I was driving with a broken lower control arm, which put pressure on the tie-rod, hence it snapped, and one of the wheels went stiff. So the car oversteered sideways, and it hit the curb. Could have been worse, really, fortunately I just had to replace the front bumper, and some spare parts.
Why this topic anyway?
I have not had an accident in my Skyline(at this stage,hope never)
Know of Silver GTR that did a while back(real mess,written off)
Mark Tilbrook has built a number of Skylines up from almost shells,
is currently building a R33 GTSt drift car from a shell, has lots of
spare parts for them,& is very skilled in repairing/modifying skylines.The only thing he wont do in house is paint, but he has a really good guy to do that(Darren-Impressive Paint & Panel).
Mark also has contacts with lots of std parts that have been pulled of cars when modified(like mine)
I hope no-one ever has a prang. But if you do - Tilbrook Auto & Dyno is the place to go.It will be a lot faster when it leaves!!
:D
well i pranged mine .. it was raining and wet .. i'm not experienced with turbo cars so i hit the accelerator a bit to hard while overtaking and totally understeered it ... hit a pole ... probably about 8k worth of damage the crash repair guy said ... luckily i had signed up with insurance the same day ... but still my premium is going to go through the roof now :D thinkin of selling it when i get it back :)
just hit the pole on the front left corner of the car .. and just broke the headlight, and intercooler pipe as well as surrounding area, and also back wheel on left, not sure it i damaged the axel(dont' know if its called that) or not ... cause i hit the curb pretty hard on the back left wheel ... i only just got insured for 2300 a year ... what do u think will happen to my premium now??
  • 3 weeks later...
lol... Drift Spec... You'd Better be careful... I've seen how you drive.. :)
When I first set the boost to 1 bar with the ebc I came on to boost in third gear with around half throttle and it snapped sideways quite badly. This was in front of Hungry Jacks On South road Darlington so the road is nice and wide. I ended up using 2 1/2 lanes to get it back.
Just a rule ppls Never pull your foot off the throttle try and keep it neutral.
The rear wheels will act a little like a handbrake otherwise and send 180degree's.
Most of you probably already know that.. ;)
what do u mean by "Just a rule ppls Never pull your foot off the throttle try and keep it neutral. " mine is an automatic ... so what happened was that it was raining and was really wet .. i pressed the accelerator to hard and it shifted back a gear and turbo kicked in ... understeer .. damn pole was in the way ... someone call 911 ... :)
What joel meant i think and what I always do is never completely take your foot off the throttle when you are in a slide, just keep it planted and pull through ( thats what I do the skyline just streightens evetually) or slowly back off.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
