OK - let your imagination run free here for a moment.
I will be OS for a couple of years and can bring back to Australia basically any vehicle as a personal import. I'm in Europe (actually Bulgaria) but can import and register right hand drive cars here, so no probs with bringing in a Jap car here first for the minimum 12 months (except for the transport costs) before sending back to Oz.
Plenty of cheap Porsches and Beemers here, but they are left hand drive and I don't want to drive a LHD car (or do the conversion) back in Oz.
I'm leaning towards an Evo 7 or perhaps an Autech S15 convertible (do a turbo conversion back in Oz of course!). Needs to be a decent sort of a car 'tho as the transport costs and rego/insurance/storage costs here will add about $10k to the vehicle.
Suggestions?
In Bulgaria huh. Lada ?
I'd go European. TVR's are about GBP40K new. Friend sold her two year old golf in the UK for the aussie ev. of $9000. The damn thing had a Recaro Factory int.
Look at the UK used classic market and you'll find some real steals there. If I was any longer over there I would have bought back a S8 Audi. Two years old and only $40K.
Just remeber that with any import insurance will be a nightmare, even thought they were delivered in Oz dosn't make it cheaper.
I'd be leaning towards a Euro car rather than a Jap car. I'm looking at buying something in the UK to go for a driving tour mid this year round Europe and the price of BMW's is criminal. I was very surprised to find a heap of them under 5000 quid! And they are 318i's either - I think there was even an original M5 in that lot somewhere. I'd imagine your budget would be alot better than mine - go Euro pimp - Audi, BMW, Merc.
OR a completely different track to go down would be the Ford GT90. Handles like a Lotus Elise and goes harder than a Ferrari 360 - well according to Jeremy Clarkson anyhow - and I think all for under 90k.. :)
FORD GT90!! DO iT!! :)
General specifications
Country of origin
United States Produced in1995
Numbers built N/A
Body design N/A
Weight 1451 kg / 3198.9 lbs
Drivetrain
Engine V12
Engine location Mid, longitudinally mounted Displacement 5.927 liter / 361.7 cu in Valvetrain4 valves/cylinder, DOHC Fuel feed
Fuel injection
Aspiration-Quad Turbos (OMG! :))
Gearbox-5 Speed Manual Drive
Rear wheel drive Performance figures
Power 720 bhp / 537.1 kW @ 6600 rpm
BHP/Liter121.5 Torque 895 Nm / 660.1 ft lbs @ 4750 rpm
Power to weight ratio 0.50 bhp/kg
Top Speed 234.9 mph / 378.0 km/h 0-60 mph Acceleration 3.10 s
Just a bit of inspiration.... :D I wanna see one on an SAU cruise :)
Good Boy Fane *pats head* - but thats not the car. Maybe it's not the GT90. The one pictured above is the older generation of the car I was suggesting. As Jeremy Clarkson said about it - "Ford have been great at making cars go very very fast in a straight line, but they must have some very stright roads in America.." It definitely does not handle like a Lotus Elise!
I'll try to find pics of what I'm talking about.... :)
Found it.. It's the new Ford GT, will be released this year. Specs as follows:
Engine
Configuration Mid, longitudinally mounted Ford Modular 90º V8
Construction aluminum block and head
Displacement 5.409 liter / 330.1 cu in
Bore / Stroke 90.2 mm (3.6 in) / 105.8 mm (4.2 in)
Compression ratio 8.4:1
Valvetrain 4 valves/cylinder, DOHC
Fuel feed Sequential multi-port Fuel injection
Aspiration Eaton roots-type supercharger
Drivetrain
Chassis/body composite body panels on aluminum spaceframe
Suspension unequal length upper A-arms and lower L-arms, coil springs, monotube dampers, tubular anti-roll bar
Steering rack-and-pinion, power assisted
Brakes vented discs, all-round, ABS
Gearbox Ricardo 6 Speed Manual , Rear wheel drive
Performance figures
Power 500 bhp / 373.0 kW @ 6000 rpm
BHP/Liter 92.4
Torque 678 Nm / 500.1 ft lbs @ 4500 rpm
pic.mv?imagenum=1&num=1689
pic.mv?imagenum=15&num=1689
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
