As the title says.
Only replacing it 'cause I am doing a manual conversion. I've never driven the car with it in so can't guarantee anything. Money back if it doesn't work :)
Southern Sydney - If you want to organise freight to pick it up from my house, know yourself out. Otherwise pick up any evening.
Cheers,
Daewoo
Edited by Daewoo
I'll take it, pending the time to swing out there to pick it up! Wont be till June or July.
Probably won't be here that long...
I don't have any garageing... all work is done in the driveway, and I don't like the place looking like a wrecking yard... send me a PM about it if you like...
BTW - how freaking heavy are they... ditching that weight is a performance mod on it's own...
Cheers,
Daewoo
Cheers,
Daewoo
What year MR30 is this from? I'm after an 84/85 four speed auto and would gladly pick it up.
Pete.
Pete.
I've thought of another angle, even if this is a three speed it would be a good exchange unit to get shift mods done. I can't PM you (not enough posts), can you PM me?
Pete.
Peter - PM Sent.
It is a 4 speed i.e. has overdrive.
Cheers,
Darryl
Darryl,
That sounds great. I'll be in the metro area on Saturday (live in the Blue Mountains), please PM me where and when. If Saturday's no good, any time to suit you.
Pete.
  • 2 months later...
I realise this has already gone but have a general question...
Does anyone know if these 4 speed autos will bolt straight into an earlier series MR30 (to replace the 3 speed auto)?
JH
JH
Yes & no...
If you have the correct flex-plate, they will mate up to the engine no-problem.
BUT, the gearbox x-member is different - you'll need to remove the gussets in the transmission tunnel that provided mounting points for the 3-speed, and drill the floorpan to suit the bolt pattern of the 4-speed member. The correct shifter plate, tailshaft and console surround are also required. (Note that the spline on the extension housing for the tailshaft yoke is a different count to the 3N71B, and FSxx71x series manual boxes...)
Yes & no...
Thanks for the reply. More changes required than I first thought. Looks like all the way down the driveline (and maybe the diff too?).
It's probably more sensible for me to fit a 'younger' or reco 3sp auto trans.
JH
Depends on what you can get from the donor car... other than cutting out the gusset, and drilling the floor, if you are stripping a car that had a 4 speed, you should just grab everything, and you will have everything you need... The thing I would be most concerned about is whether the ECU is the same...
Cheers,
Daewoo
  • 3 weeks later...
...The correct shifter plate, tailshaft and console surround are also required. (Note that the spline on the extension housing for the tailshaft yoke is a different count to the 3N71B, and FSxx71x series manual boxes...)
Thanks for the info. Don't have a donor car unfortunately so...
I'm looking for a flex-plate, tailshaft, shifter plate and console surround for series 2 R30 4 speed auto. Does anyone know if any R31 items will fit?
(So far have located 4N71b auto trans, cross-member and VL driveshaft).
JH
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
