Hi Guys
Im looking into possibly buying a Stagea NM35 by about August this year
What I was wondering is
What turbo actually fits the NM35?
I had read that its the same as the RB25 turbo, however I dont think this is the case with more research
Im mainly after any idea as to an option other than Hi flowwing, Is there one?
I realise they take a while to remove but I thought Id look @ getting a 2nd hand one & getting it rebuilt B4 the one on the car craps itself
Change it over in 1 go, ie exchange program
Are there any other options out there?
Cheers
Mark
https://www.sau.com.au/forums/topic/318148-stagea-nm35-turbochargers/
Definitely not the same is an RB25 turbo.
If you are high flowing, talk to Andy65b, I believe he still has his blown unit.
As for a direct replacement, I have seen HKS GT30's put on (most common replacement in Japan) but they require minimum a new dump (which you will need anyway) and probably an exhaust manifold as well.
High flowing is the easiest and cheapest way for our turbo, no question due to space restrictions.
So many variables. Bush or Ball Bearing, how big do you want the wheels? 360 degree thrust washer? I guess anywhere from $1k to $2.5k.
Cam have you seen GT30's being fitted? I have only seen the GTRS's, got any pics?
Dont think Id want something too crazy
Just looking @ getting a good reliable cruiser between Sydney & Brisbane
Probably go ball bearing & steel rear impeller
That way it could take full 3" without any drama
What sort of boost could this then reliably take?
Looking @ around 1bar or so??
The M35's got different type of casting on the turbine but same 6 bolt dump pattern. The intake side is also different with a flange bolt.
The common profile we put in to those are the 2871RS 52T BB or Sleeve bearing CHRAs. will support about 240rwkws with supporting mods with stock sort of response.
Hi Mark
Yes, I still have the spare turbo that I can loan out on an exchange basis. (small cost)
The standard turbo has as standard 14-15psi you don't need to look too far from the standard turbo to be betting your aimed boost. The rear ceramic turbine is known to be a weakness and can fail. Most seem to get a bit more than the 100'000 before failing but some have failed earlier but also some of these cars have had dogey odometer readings.
I am running a full 3 inch exhaust from the stock turbo back and it is a great car to drive. fantastic on the open road and great response around town.
Cheers
Andy
No worries
Thanx for the offer Andy
Ill see how I go as Im not going to do anything till at least August I thiink & I have to see which way I go
Either Leggy Or Stag
Just really nead to drive both & work out for myself what really fits my needs.
I know everyone here willl say Stag, theres just a couple of things on both that worry me a little @ the moment
Other than the turbo, what worries are there? Very reliable in general. Have you driven them both?
You have to remember you are buying a cheap auction car that has probably been sold because there is maintenance required. I would hate to think what Nissan would charge for a turbo replacement over in Japan.
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
