  • Replies 78
Still havent got the camera back, but the car hasnt changed from the pics, its just been cleaned up a little.
The Power FC and Z32 afm with HKS pod have now been advertised in the Parts For Sale section, so first prioty is no longer with the buyer of the car. They are priced at $1800 and $350
Car is in the Trading Post this week...
Can't believe there is no great intrest in this car
I guess being a 32 owner and having spent the best part of all my money on mine, I can see real value in this car
I think the fact is people think of 32's as a cheap performance car, and you can pick them up for under 15 grand, usually a pretty crap example but its a 32. Chances are if you where to buy a cheap 32, you'd end up spending more just get a half decent car at the end!
For the 20g's asking price, this car has MASSIVE potential
Considering the average 32 seems to go for around 15, for a extra five g's you are getting a truly fast street car, a 2835 should support around 260rwkw on a RB20, which would make it faster than even a midly worked GTR. To put it into perspective, Clint32's car made around 235rwkw and ran a 12.8 at 113mph, with this turbo, and decent tyres and launch, a high 11 low 12 should be possible
To buy a stock 32, and to get it to this point, I doubt you would get change from 30 grand, for the 20 grand asking price, this car is a bargain
It takes a true enthusiast to appreciate and own a car like this, and no doubt thats the type of person who would buy a car like this, not someone who is jumping on the drift/import bandwagon and is looking for a cheapie to have some fun with
Hopefully you will sell it soon, as that old saying goes - spend a little more now, save a heap down the track
good luck with the sale
Chris
Thanks for the confidence boost Chris. There's plenty of people around who appreciate the car, but no-one wants to buy it. Dont really understand why someone wouldnt want to pay a few thousand over a mildly modded 32 to get all these extras. Turbo alone is around $5000 to replace.
Big Bump.
$19,500
otherwise im taking all the shit off and selling it as a NA :rofl:
Chris
Is this thing still for sale?
Wanna swap for a 32 GTS4 plus cash adjustment? HAHAHAHA
I still can't beleive that no one wants to buy this thing, i mean common people its a bargin!
yeah unfortunately i'm not getting much loving.
would think about swaps, but at the moment i need the cash to pay off some debt.
need to sell people.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
