  • Replies 78
So what is "wrong" with it as far as the RWC goes?
I'd love to buy this dude!
AWESOME CAR!
Worth more than your asking, i dunno what these crack heads are on about but you will easily get that!
Are you throwing in the Power FC for free with the car?
I mean with that in and tuned i'd expect, what...... 250-300rwkw?
RWC comes down to searching around and finding someone that will do it. when i find a buyer, then we'll just have to work together to find someone. but it can be done
the powerfc does not come in the car. that is a seperate sale.
i was planning a pretty conservative tune and would be happy with anything between 230-250 rwkw. but obviously the turbo is good for more than that.
Hey man just a few questions.
Where abouts are u located? Would u do 20 with a rwc included?
What sort of aftermarket manifold is on it, as i can see the turbo is high mounted....
Interested
ThanX man
Simon
gday. welcome to my thread.
im in melbourne also.
the car is sold as is. BUT im sure we could work something out. apart from rear tyres and turbo/wastegate setup, it should be rw.
i think the manifold is HKS, cause it seems to be a complete kit and its the same as pictures on the net. but it doesnt say HKS anywhere. it is stainless steel, and its just had some cracks welded up and the plate trued. and wrapped in exhaust wrap.
peace out
I have a trusted Mechanic who happens to be a family member and has looked at a few cars that " looked ok" but found many hard to pick things and has prob saved me thousands of $$ in the long run so i get him to check everything out for me and he wouldnt have the time for a trip to melbourne.
Sounds paranoid but its not much different to importing a car from Japan, minus the language barrier.
Dude, i'm not interested in buying the car, but i wanted to comment on how sweet it looks. Awesome and cheap. Maybe you should sell it for more as people might think it's stuffed for the price you're asking :)
Anyway a free bump. Good luck with the sale.
Scott
hmmmmm i dont think that is the reason that people arent buying this car. i think it is because most people that want an r32 are looking to geting one for closer to 15g and that is up to them. i think you need to have a love for 32 to want this car (i am one of them :) people think just because you car get a 32 for 7g under the new 15 rule that all of them should be cheep "not the way it happens!"
good luck with the sale - if i sell my car befor this car goes i will be in contact.
regards, jonathan
hmmmmm i dont think that is the reason that people arent buying this car. i think it is because most people that want an r32 are looking to geting one for closer to 15g and that is up to them. i think you need to have a love for 32 to want this car (i am one of them :P people think just because you car get a 32 for 7g under the new 15 rule that all of them should be cheep "not the way it happens!"
                        regards, jonathan
yeah i always knew that would be the case.
its no surprise that most of the people giving the car props are owners of r32s and/or modified cars in general.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
