  • Replies 78
Still havent got the camera back, but the car hasnt changed from the pics, its just been cleaned up a little.
The Power FC and Z32 afm with HKS pod have now been advertised in the Parts For Sale section, so first prioty is no longer with the buyer of the car. They are priced at $1800 and $350
Car is in the Trading Post this week...
Can't believe there is no great intrest in this car
I guess being a 32 owner and having spent the best part of all my money on mine, I can see real value in this car
I think the fact is people think of 32's as a cheap performance car, and you can pick them up for under 15 grand, usually a pretty crap example but its a 32. Chances are if you where to buy a cheap 32, you'd end up spending more just get a half decent car at the end!
For the 20g's asking price, this car has MASSIVE potential
Considering the average 32 seems to go for around 15, for a extra five g's you are getting a truly fast street car, a 2835 should support around 260rwkw on a RB20, which would make it faster than even a midly worked GTR. To put it into perspective, Clint32's car made around 235rwkw and ran a 12.8 at 113mph, with this turbo, and decent tyres and launch, a high 11 low 12 should be possible
To buy a stock 32, and to get it to this point, I doubt you would get change from 30 grand, for the 20 grand asking price, this car is a bargain
It takes a true enthusiast to appreciate and own a car like this, and no doubt thats the type of person who would buy a car like this, not someone who is jumping on the drift/import bandwagon and is looking for a cheapie to have some fun with
Hopefully you will sell it soon, as that old saying goes - spend a little more now, save a heap down the track
good luck with the sale
Chris
Thanks for the confidence boost Chris. There's plenty of people around who appreciate the car, but no-one wants to buy it. Dont really understand why someone wouldnt want to pay a few thousand over a mildly modded 32 to get all these extras. Turbo alone is around $5000 to replace.
Big Bump.
$19,500
otherwise im taking all the shit off and selling it as a NA :rofl:
Chris
Is this thing still for sale?
Wanna swap for a 32 GTS4 plus cash adjustment? HAHAHAHA
I still can't beleive that no one wants to buy this thing, i mean common people its a bargin!
yeah unfortunately i'm not getting much loving.
would think about swaps, but at the moment i need the cash to pay off some debt.
need to sell people.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
