hey guys how yas doing, ive recentely upgraded the turbos on my r32 gtr to hks 25/30s, is there any way i can run watsegate or 2 of them some how, the car has just been done, ive never dealt with an external wastegate but was just thinking is it possible to put it on the gtr, btw its low mount, as much replies would be appreciated thank you
Kind of hard to understand what you are asking. You want to know whether you can run an external wastegate (or two) on your setup which is currently running internal gates? If this is the case, why?
Edited by PM-R33
yeppp thats what im asking, i wa sspeaking to a few boys down here but i didnt really want to go with what they said, id rather post it on here as guys from here would probably know more, its running the turbos as ive mentioned above
Ok I thought that's what you were asking.
So back to my question I posted, why do you want to go to external wastegates when the internal wastegates on 2530s work perfectly fine? Let me guess, screamer pipe?
yeah man i just want it to work better, if its better running the internal ill leave it but if external is bvetter for it ill do it, what would i have to do though?
nahh man got no boost controller problem was just thinking if its better ill go ahead and do it, i just want to knwo what will work better for my car with these turbos, internal or an external, if external how is it possible to do?
Nothing wrong with the 2530 internal wastegates. Been running em with HKS dumps for years and they do not spike, creep etc.
The wastegates are a lot bigger than the pissy stock ones. Dump pipes that have a separate outlet for the wastegate gases is the way to go with less turbulence than the stockers.
Yep the stock internal gates on them are completely fine and the amount of money you would spend turning them to externals would be money better spent elsewhere. Not to mention to absolutely no benefit.
yeah im running hks 25/30s with the older style tomei dumps, what will i need to make it external, what would need to be changed as ive never chased information on these, what wold i need to take off and purchase?
Whoever these people are
"i was speaking to a few boys down here but i didnt really want to go with what they said"
Then don't listen to them anymore, they clearly have NO idea what they are talking about.
You do not need external wastegates for HKS 2530's. They work perfectly fine on their own.
There is zero performance gains by performing such a modification.
The only thing that will happen is you wasting your money
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
