Is it just me or is the dip stick a total pain in the arse.
Can anyone help me out.
Every time I check the oil level ,one side of the stick show low and on the other side over full.
So whats the best way to get a good reading?????????????????? :P
https://www.sau.com.au/forums/topic/318210-checking-oil-level/
So whats the best way to get a good reading?????????????????? :thumbsup:
Check it first thing in the morning if you park on level ground before you start the engine.
thanks for that but thats how I always do it.
Ok let me start by saying I have had many cars and worked as a Mechanic so the checking part isn't the problem
What I dont get with this car is the reading on the stick
The reading is shocking????????
anyone else have this problem and a solution
I get this problem too. I think the oil is sticking to the walls of the tube and providing false reading.
Try pull the dipstick out, wipe it and leave it out for a few minutes to give the oil in the tube a chance to drain away, then reinsert, remove and read.
This has been my biggest bugbear with the VQ. Checking the oil is a major PITA. The dipstick is awkward to remove/instal and it's so difficult to get a consitant reading. You are not alone here cra-z-boy. daisu has the right method. Remove the dipstick, clean & WAIT for the oil in the tube to drain back. Also take a few readings and work on an average.
How long does it take to change your engine oil then? Must be a long and nervous exercise as you are unsure if you have overfilled or not filled enough?
Is this how the garages do it?
