Great info as usual. Thanks … im already running a hks oil cooler. I will check my coolant mixture - that’s interesting. I guess if the problem persists the next stage is to run datalogging but I will need to do this when the temperatures are crazy hot. Hong Kong is going thru a heat wave right now.
Yes still have that .. what to keep the stock parts and plastic bits relatively stock looking as I started off with a pristine vspec specimen. Will resell her in a couple years. Is this stroud restrictive?
I am wondering how much the plastic hat plays into this. Both of mine melted more opposite the wire crimp. Tried the efihardware ones , double washers , better eye terminals. The seat of the plastic ring inside the metal hole is very thin 1mm or so and you are putting through a threaded bolt, which can cut the plastic, won't take much for some conductivity to occur in a metal fuel hat that is earthed. Amp draw of pump is going to be a variable here too. many things that impact that.
Because he's using a different product, designed different, works different. Can create a problem.
