stripping the 32 as ive purchased a 4 door-
gtr front bar with lip
fibreglass copy
lil bit of damage
easy repair
$150
r32 gtst stock rims
16" with rwc tread
$200 for all 4
3" front pipe(dump to cat)
good cond
$100
turbonetics 35mm external gate
$150
blown hypergear tr43 turbo
needs bearings
35mm tial copy gate welded to exhaust housing
v band dump welded to turbo
$200
rb20 r32 engine loom
$150
rb20 manual ecu
$100
stock r32gtst fuel pump in cradle
$50
rb20 auto gearbox
mint
$200
auto tailshaft
$80
r32 gtst 5 stud brake setup with hubs etc
calipers,rotors,pads,hubs etc
$500
r32 brake master cylinder and booster
$100
2X r200 lsd's
both mint one has 70k other 110k
$100 each
rb20 green label afm
$80
r32 gtst passenger seat
mint
could do with a clean
$80
r32 tail lights
$100 the pair
r32 headlights
projector style
$80 each
right hand orange indicator
$40
r32 blueface instrument cluster
130kms
$50
gktech steering wheel with boss kit
$100
r32 front subframe
$50
r32 rear subframe
$50
r32 front lca's
$100 pair
r32 stock front swaybar
$50
1992 r32 gtst bare shell with all glass,dash pad etc
green
all panels
pedal boxes
fuel tank
jap tint
reg'd in VIC
no defects ever
$500
car has til friday to sell whole then mass strippage will be happenin
0431683303
northern suburbs adelaide
Hey mate i just need the rear 5stud hubs and brake setup.
Are you willing to separate and how much for?
Also interested in the engine loom if its for an rb20det.
Pm me.
Cheers.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
