gday guys
just got me r32 the other day and upon driving it home just on dark turned the lights on hit high beam and ever since high beam light on dash and actual lights are stuck on ie i have no low beam. my guess is the the blinker/high beam dim dip switch? and im guessing there's a relay in there thats locked closed some how? any ideas and if im on the right track?
thanks
https://www.sau.com.au/forums/topic/318241-help-please/
You're indicator bar / light switch isn't just pushed forwards to the high beam spot? I had a similar issue in an old car of mine and it ended up being that whole indicator bar... replaced that and was all good.
https://www.sau.com.au/forums/topic/318241-help-please/#findComment-5201071
I have seen them go for anywhere between $60 -$150 from a wrecker. Take a look in the For Sale (Private Car Parts and Accessories) forum. They come up in there every so often.
Edited by S1LV3RTRACKS
https://www.sau.com.au/forums/topic/318241-help-please/#findComment-5202067
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
