hey just curious i havent seen mine com on in years
i here its got somthing to do witht he air con
but also its trigerd by the water temp switch in bottom of radiotor any one know what temp activates this switch for the thermo fans to kick in
thanks in advance
https://www.sau.com.au/forums/topic/318245-r32-air-con-thermo-fans/
I was told by an air con guy that is it for the aircon (there's only one fan right?), and will comes on when the refrigerant gets too hot (ie when you're in traffic). So there must be a temperature switch in the refrigerant piping somewhere. Mine comes on, but a bit too late (ie after i'm getting ambient termperature air from the vents). You could try carefully blocking all airflow through the heat exchanger then putting the aircon on max and it should come on eventually - might take five mins or so of idling.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
