I took my M35 on a decent cruise this weekend and it appears to have an intermittent fault in the factory cruise.
Sometimes whilst cruising along, there is a beep followed by the car dropping out of cruise. The sensor signal on the right lcd on the dash (car symbol and three bars and dot) flash and an orange 'cruise' lights up to the right of the green 'cruise' on the dash. The only way this can be reset is to turn the car off, after which it appears to work normally.
The second problem it was showing this afternoon was the beep again, followed by dropping out of cruise. This time the orange 'cruise' wasn't there, and the three bars and dot were flashing on the lcd but no car symbol. I could reset this condition by turning the cruise off and on again with the steering wheel button, but it kept on doing this...very frustrating!
In both cases, there were no cars infront or other objects that may have interfered with the cruise as far as I could see.
I have checked for fault codes and it comes up with 1110 (three single flashes then ten flashes), but there's no listing for that code that I could see. Is it the same as the V35 which I think is P1110 Intake Valve Timing Control, LH Bank??? This is no doubt a separate issue... I will reset it and see if it comes back.
Any ideas? Or is this just prompting me to lose the factory cruise, which I don't want to do!
https://www.sau.com.au/forums/topic/318248-m35-cruise-problem/
Loose connection to/from your cruise module?
Did you happen to his any bumps before the beep by any chance? Just thinking that if the connection was not great, perhaps the plug was jolted loose?
(have no idea really, so just taking an uneducated guess :happy: )
No, no bumps, jolts, low flying birds (!) etc. I suspect an intermittent electrical gremlin as it isn't putting up an error code on the computer. Just wondering if anyone else had experienced and fixed this.
Anyone got a spare radar sensor for the front grille? Hate to think what they'd cost from Nissan!
Wow, that quote just sent a shiver down my spine... and I get "good" prices from Nissan!
Perhaps PM Chris Rogers? He may have a spare radar sensor, although due to the rarity of the item I think you will need all the luck you can get!
Have you played around with the cruise control wiring? I was reading your last post on how you wanted to get more than 110 by using a circuit from jaycar. I also have this cruise control. I never use it because when cruising sometimes it sees on coming traffic and shuts off esp left hand turns. And also I cant go above the 110 limit and everyone passes me. When you get the warning lights does it try and put on the brakes aswell? Ive tried following a car in front of me with cruise on right up to an intersection the cruise started braking with warning lights on dash and it slows the car right down to about 5 kms. It was a fast stop and i was impressed it colud do that. Try following a car right to stopping point to see if yours does the same. There should be warnings during normal driving but it should still reengage. You could also try setting the distance closer so its not picking up far away objects.
Haven't played with it....yet....
It was working exactly as it should except when it was faulting. Normally it does the braking, warning beeps etc. When it faults, it emits a single beep, drops out of cruise and the dash display starts flashing, either with the orange 'cruise' or not. I played with the distance setting and it made no difference to the problem.
I tried it on a drive to the shops just then and it was working just fine, of course!
  • 9 months later...
just my 2 cents when i had the loaner m35 i had the exact same issue (the beep and drop out of cruise) when i indicated to overtake.. figured it may have a safeguard which stops you indicating (overtaking) while on cruise.. tho could have been also been distance from the guy in front though was a fair bit away.
I think I updated another topic- fixed the problem. Was either a dirty set of lenses for the sensor and/r dirty wiring contacts. Took it all out and apart, cleaned it all, marvelled at all the electronics inside the sensor box, put it back together and it's been working flawlessly. Up to 110!
I wish someone would hurry up and crack the computer programming so they can take out all the speed limiters!
  • 11 months later...
this is exactly what my car does, only i have no lights on the dash.....ever
when you say sensor, do you mean the radar??
Cheers
Andy, please PM me the winning lotto numbers for this weeks draw.
Hi Guys,
I have the same problem with my car as well.
First of all I ripped off the front grill and gave my radar a good scrubbing which seemed to fix the problem for a while. however the problem seems to be coming back more and more frequently.
The only other variable I can think of is the Black plastic which sits in the grill with the Nissan badge on it is starting to fade and show spots all over it, I'm wondering if this is causing the issue as well.
Anyone have any ideas where to buy just the Black plastic part of the grill from and cost
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
