Hi guys, i recently purchased an R32 GTR from Japan. Ive had it for 2-3 weeks now. The problem is I used to be able to rev to 6-6.5K rpm, and drop the clutch and the car would just rocket start off the line . Pure traction. A week and a bit later, (I probably did around 10 launches :thumbsup: ) and it wont do it anymore. It will just spin the rears up, Not like in RWD mode, ive experienced that, but just feels like i have real shitty tyres now and doesnt get grip, but still tells me that nearly 50 percent tourque is going to the front. Meanwhile the tyres have excelent tread levels at all 4, they are 255 width Potenza RE01-R at all 4.
Any ideeas?
Oh and sometime after hard driving through the mountains the 4wd light would go on. I just turn the car off and back on and it goes back to normal. Also the ATTESA fluid is on max.
Thanks guys.
https://www.sau.com.au/forums/topic/318255-launching-r32-gt-r/
From memory there is a small leak somewhere in your Hicas system that triggered the light.
As for the launches, there could be too much AIR in the clutch system (?) or the clutch packs are worn? Best to take it to a GTR doctor, i used to take mine to Racepace in Bayswater but its totally up to you, go to the Vic section to see their contact details.
....Oh and sometime after hard driving through the mountains the 4wd light would go on....
I think the car is telling you what's up already. take it in and get it checked out.
Edited by istdercollen
My problem is that it feels like my clutch is slipping, lots of revs but not much go (at least not by GTR standards). I'm moving to Bayswater this week so racepace sounds like a plan.
I would say your case is a new clutch.. if you don't change it soon, you will be like me a few years back. I had a clutch die in an S2000 and to avoid towing costs I drove it to the shop 40kms away doing 9000 rpms in 6th gear just to go 90kmh.
LMFO :)
Sounds like your clutch packs in the transfer case might be worn, Check all the hydraulic actuation stuff first (bleed attessa, check for leaks and check attessa code on computer in the boot, see if it's flashing). There's a simple test you can do to see how well the transfer is gripping, if your mech knows about GTR's or has a workshop manual for it it's easy to suss. If you end up needing replacement clutch packs for your transfer case let me know- I've just done one and if you want to halve the cost you get quoted I can do a swap job for you.
Fair enough mate , that probably sounds about right. Clutch seems ok but transfer is a bit iffy.. I just went in my mates R32 and it grips much better than mine in the same situations. His 1st and second grip in the rain, I step out in 2nd lol.. And what do you mean by swap job brother??
whats the simple test you can do to see how well the transfer is gripping?
Thought I'd seen it in the workshop manual and it's not there, i'm sure I've seen it somewhere. Don't want to give details yet as if it's not what I think it could be a little unsafe. I'll keep looking.....
  • 4 weeks later...
It's not too bad, just clutch packs are fairly simple, not too much disassembly- but you'd really want to check the shimming on the clutch hub and maybe replace a few bearings while it's out, you be thinking of doing it yourself?
Oh still can't find the factory test - I'll try and devise something that'll give some sort of indication of wear
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
