hey guys
got a silver top RB20det from my r32.. will sell it as a complete get up, excellent conversion for yo s13/s14/s15/r31
was removed running, no smoke, no noise, happy daily driver with 113000kms on the dial, engine has no dramas, stock boost on stock turbo since being imported into aus, no sign of any gizzmos or gadgets been installed.
R32 RB20 crossmember, ECU, engine loom, new waterpump and timing belt, new headgasket, alternator, p/s pump, starter motor, exhaust manifold, turbo, half worn clutch, good gearbox, engine mounts, engine fan.
i did the headgasket and water pump/timing belt as soon as i purchased the car, as a precaution only.. there was no need for it, i just like to do it, eliminates any future problems.
*missing top and bottom plenum and coilpacks... thats all*
can put it all on a pallet and freight it to where you are.. wherever that is..
to buy this as a halfcut you'd be looking at $2200 or so, so this should be a bargain at $1700 + freight.. or if you think thats a bit rich, make an offer.
pick up in east maitland or thornton, or can deliver to newcastle nsw.
pm me or msg 0431646160,
cheers
Linton
Price Drop... $1500 + freight.. it will be all wrapped up on a pallet
sorry guys, i didnt realise i had replies, thought i had subscirbed to the topic but obviously not.
Do you have a photo if the coil pack wiring loom,
I'm trying to figure out if it will fit my early rb25
i think rb25 has differnt coilpacks but ill get you a pic anyways
are they just stock injectors
yes.. all stock... everything on this engine is completly standard.
are you willing to part with the igniter pack if you have it at all? cheers
not willing to part it out at this stage.. shouldnt have sold the coils or intake really but im trying to chase some up.
