Selling some stuff I got laying around after sale of car and some stuff I never fitted to it as well.
Front brakes calipers and rotors, brake lines and pads. Came off due to brake upgrade. $200
(no pics yet)
Racetech 4009 standard width seat and low rail. Like new. Was in 32 gtr. $800
Marks on seat are from the harness resting in it for a week prior to taking the photo.
Willans 4 point 3" harness - like new $250
N1 rear pods - fibreglass $100
N1 boot lip - fibreglass. Some damage attempt at repair by someone at some stage $30
In Melb and prefer Melb pick up
Archie
0419 714444
Im interested in the rear pods if your willing to give me a price posted to NSW 2173.
Thanks.
Update:
Found some more stuff that i had forgotten about after paying a visit to my mechanics workshop on the weekend
I believe it's a Fujitsubo 3" exahust, high flowing muffler in mid section and Jasma rear cannon muffler.
Very quiet.
No probs with 360rwkw when fitted to my old 32 GTR.
$200
Also, brake rotors went missing and so too did the pads so all there is are the calipers and the brake lines (incl rear lines too)
Here are the pics $100
Also N1 pods are plastic not fibreglass.
They came off an immac silver 32 gtr....u know about those all too well ;)
That should justify the freight costs in itself!! :cool:
100 inc freight...thats all they are worth for me. Ill give you two Edith Cowan's and you can give me two calipers.
  • 5 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
