Guys and gals
Just thought I would start a new thread to discuss the new Poliscan multi lane speed cameras.
I just had a read of the PDF document that states its features etc, and WOW , pretty amazing
(amazing in a " you're totally screwed " kind of amazing )
As I am sure you are all aware its now run off Laser ( LIDAR?) so if your existing Radar Detector picks up Laser really well then you at least have SOME warning. I went thru one that was being tested over the weekend, the radar detector went nuts but didnt give me much warning at all.
Discuss??
Poliscan___speed_camera_poliscan_speed_03.pdf
  • Replies 47
Posted Images
Looking at the specs the Operatiional Range is 15-75m , so it will be interesting to see what range people are detecting it at ( on Radar Detectors ) , if you are getting 200m warning then at least it gives you a bit of time to slow down,
It comes across as media and Police are overstating some of its abilities in a big way.
I think the only areas in fines enforcement it will improve is lack of warning for those of us using existing radar detectors...
AFAIK jamming frequencies when you don't have a license to transmit on them is a very serious offense.
Can also fall under perverting the course of justice and it's just generally a bad idea, Police aren't stupid they will realise your 'laser parking sensors' aren't for that purpose. Eg If a Poliscan camera takes your speeding reading and instead of 76 km/h it says "X7uyP1 km/h" questions are going to be raised and probably your vehicle will be examined with or without your consent. This will be made easier by the fact Police have a clear photo of your license plate and your residential address.
Be interesting to understand some more of the tech stuff behind it.
If you have an iphone use the trapster.com mobile application with push notifications to warn others, and receive warnings on mobile speed traps.
Otherwise take it easy until some more passive counteraction measures have been tried & tested! Not that I speed anywhere, just get to the limit quickly :)
Cheers
-dave
ahaha.. sponsored by Coopers Pale ale! My kinda MAN!!! But I far prefer the sparkling ale ;)
I am more interested in the technical / real world side of things. Like how much notice will you get, will you get ANY notice if you have passed it
Oh well just need to wait till a few more people go thru it when its " live "
Cheers
-dave
Edited by ssshonky
There was one being tested on Monday just between the GEH exit and on ramps heading south on Tonkin.
Caught a glimpse of a car behind a tree as I came off the bridge then my detector starting going spastic on LASER LASER and normally I expect to see a cop pointing something at me.. but it was one of these new setups.
Come to think of it, it was actually going off Ka AND Laser.. and there appeared to be two units on the side of the road (a normal multinova looking setup and some wierd new setup), I assume they were testing for accuracy between the setups.
I had a good 100m notice but the problem with Laser (or at least with the handheld units), is that as soon they paint you they pretty much have a reading, as opposed to multi's where you have a few seconds grace.
thanks man thats JUST the kind of info I am chasing.
If you got 100m warning for laser then I guess if the camera is operating at its furthest range then you will only get 25 m warning, not that much at all hey?
From what I can gather this is going to differ from the handheld Laser guns as the Poliscan will probably wait for you to get closer then take the photo? With a cop he can ping you a good distance away then just pull you over when he sees you get closer.
Does anyone know if they are going to decomission the Multinovas and replace them with the Poliscan units or are they going to ship the Multinovas off to country towns?
If they decomission the Multinovas then its going to change the focus of what people will be looking for on Radar detectors, before it was good KA band detection, now Laser might be more what you want a detector to be good at.
I could probably get more warning but I had just crested the rise over the bridge, if I come across another one with a stretch of flat road preceding it, I'll report back how much warning I get :D
Nope! Painted green. They are fairly large but I think they will be targeting more the multi lane roads , so you have to think of other cars in the inside lane blocking your vision.
arent these in some stupidly big white box??? kinda easy to see i heard
Most if not all scramblers/jammers are a complete waste of time in australia, unless your in WA where detectors are legal. The highway patrol cars all have spectre 3 RDD equipment now, and if your jammer is operating you will make their RDD go balistic.
You might as well be driving down the road waving flares and sparklers out the windows.
Our highway patrol cars here run K-band radar equipment, on a nice road I'll get nearly 1km warning!
No need for a radar jammer if you have a good detector.
Good laser jammers only transmit when they pick up the incoming beam and even then only transmit for a very short time, basically to allow you to grab some anchors before their unit tries for another reading.
Hence the reason I put it in the Western Australia section :)
Hey Bubba what detector are you using?
Oh and in regards to the Jamers , basically the device will send out the Jamming signal then physically turn itself off for a certain period of time. So if the cop goes for a second reading they *should * get your propper speed.
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
