Hi guys. I need a second opinion on my GTR. When i start her and let idle to warm up, after about 5mins high pressure steam shoots from the engine bay. Its fkn lound like air from a compressor and i nearly shat my pants. So not to take chances i towed it to the workshop and let them suss what happen. The first few times they stared her up it happened again and then this recent start up nothing happened. They said the radiator did not need that much toping up maybe 1/2 liter and there was no obvious signs of coolant on the radiator etc. Apparently temp gauge was reading fine although the twin thermo fans went on. They need time to find out whats going on. But they stated that my oil pressure was way to high. The defi gauge was running almost to max. And when she reved the pressure increased and apparently its not meant to? Coz i run a JUN pump it has a adjustable vavle to prevent this. the oil pump needs to be taken off to inspect and adjust valve if needed. But aprrently this is trial and error as there is no info on jun pumps as to what adjustments equal pressure. Said it will be labour intensive as the sump needs to be taken off to acces the pump and the cradle, radiator, balancer needs to come off. It has thin run in oil for the bottom end which may effect oil pressure? I remember last time that the oil pressure was high at start up but came back down after she warmed up. Can i grab people opinions and advice as to whats happening?
https://www.sau.com.au/forums/topic/318300-jun-oil-pump-problem/
well when cold the oil pressure is quite likely to be around 8bar. that's not really a problem and it will change a fair bit depending on what type (and weight) of oil is in there and also what the ambient temp is (colder it is higher it will go).
now, the real concern should be what the oil pressure is once the car is at operating temp (80 degrees C give or take 5 degrees). at those temps pressure should be around 2 bar at idle and will increase with revs. ideally it should go much higher than 8bar at max rpm when at operating temp as things can go bad with too much pressure.
these two problems may not be related at all. and if it's just a matter of seeing 8 bar pressure at cold start then that's not really a problem at all.
i would check the thermostat first to see if that's opening at all.. water shouldn't be boiling just from oil pressure being so high at start up.
make sure the water pump is still working as well.
also where is the steam coming from?
+1
I take it you meant to say it "shouldn't go much higher than 8bar at max rpm when at operating temp as things can go bad with too much pressure". I have seen similar issues when relief valves get stuff shut. I have seen up to 9.5Bar pressure dead cold with a slight rev to 2000rpm with this issue. consult your engine builder for what he expects the oil pressure should be - they all have different opinions.
    • It's actually really good advice. And I do try to do it. I actually have 2x 3KG dumbbells that sit right beside where I sit. And I look at them a lot. Use them a little. But I'm trying to do more with it. At the moment I'm going through a heap of weight loss too which will help. I cracked into the 85kg mark this week. My weight used to have me sit consistently between 93 to 95KG! That definitely doesn't help. I've also got POTS, which flared up after I got slapped with COVID a few weeks back, and POTS really smashes fatigue and stuff into you, and has a thing even called "excercise fatigue". Basically even the minorest "excercise" (walking from the garage to the house) causes fatigue! And one of the treatments (Other than a med I'm on) is also... Excercise... Ha ha ha So it's why I'm trying to play the game of "might as well" and trying to push through things. For ADHD specifically, the general recommendation is "excercise". When you dig deep into it though, while any excercise is good, the best type is "explosive" excercise. So training for a sport like squash, tennis, even soccer. Things where you need to get the whole body able to "explode" into a different direction change. They've found with explosive sports, (I can't think of the proper term they have for it) that it actually makes the brain grow and become bigger in specific areas. The areas where ADHD causes those parts of the brain to be smaller than normal! But definitely, trying to push myself, and break those bounds mate, and get healthier!
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
