could not have said it better myself. having owned several signed vehicles myself, when it does come time to remove it you will have a $25K car that will be worth NOTHING due to the damage the removal process caused. think twice.
  • Replies 45
Almost makes me wanna get the stanley knife out and do it!!!! I always wanted to matt black my car(s)....In fact, I was in the process of rolling on matt paint to my mx5 in colorbond "woodland grey"....kinda ran out of time when I got a job offer the 2nd day I bought all the paint....LOL..
If you ask me, matte black works on a few different cars:
1 - Old and crusty vehicles / track hacks
2 - New and expensive vehicles (think supercars, high end euros, etc)
Anything else (such as the V35) is a gamble. As mentioned you need the perfect set of wheels, in an agressive offset, and the ride height to match.. otherwise, i think its a bit like fitting one of those GTR look-alike front bumpers, if you know what i mean.
Good luck and make sure you post a write-up!
A little paranoia over the whole damage your paintwork trip. This process has been around for a while and is widely used on very expensive sports cars to protect the paintwork on track days. Emphasis here on getting the best quality product and having it proffesionally installed.
http://www.decentlyexposed.com.au/home/aut...CFYsvpAodHSArEw
Turned out pretty good - altho I accidentally fooked it up toward the end and then just got careless as you can see on the RHS coz I knew Id have to do it again. (note - its probably best not to attempt this whilst hungover.)
LHS looks good though.
Will be good to see how the paint holds up when I pull it off.
Before:
After:
oh well - its only like $20 for 2 meters so cant complain - looks good otherwise I think. time to order some more.
nice work dude!!
Lol there are a couple of imprefections but i guess thats expected, the big peel near the right exhaust pipe is fairly obvious i suggest you do a quick patch job on it! If i had done it i would have made a stencil first then cut it out, possiblly get a closer/smoother finish.
Just go all carbon and be done with it, installed it on a few cars now but haven't had the chance to do a complete car yet. It is a lot tougher as well, we use it on a few cars including some Westfields.
The normal Wrap material is easier to use then the Carbon stuff so if doing a large body panel buy some normal wrap as also cheaper and see how you go at laying up before you spend a fortune on the Carbon stuff.
that carbon weave looks fake cos it's got no stretch around edges like a real weave. but it's leagues better than the printed carbon vinyl I guess cos it's textured. shame it doesn't come with clearcoat and you can't spray it.
Carbon fibre can't stretch so I'm not sure how you arrived at your conclusion. The fact that there IS stretch around edges would give away it's vinyl. From a distance it doesn't look so bad but still no fan.
Stretching is easy as per images below, we can clear coat it but if material moves the clear coat cracks and it just looks black at a distance.
It is an option over painting a whole car if a bonnet is faded wrap it instead of trying to blend it into whole car, stone chips can be a pain on some cars and this is a lot thicker then the clear over laminates used for stone chips. Also have dash parts that are damaged and cant replace cheaply, a few cracks sanded over and covered is a cheap option.
It isn't used just for a "Carbon Fibre Look" it is may as well use that pattern, could always use the wood grain pattern.
that woodgrain looks amazing!
would be such a bitch to line it all up tho
FYI I have developed a slight addiction to this cast vinyl, Im covering all my sliding doors on my balcony with black vinyl, and will prob do my wardrobes too lol
So many uses for this stuff, its great! :D
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
