Cheap and easy way of raising the ride heign of your car. Just throw it on top of the shock body and bolt the shock back into the car. Dont see the point myself, unless you are the fiddling type with non height adjustable shocks and you want to go uber low to normal for some reason regularly
  • 1 month later...
I very much see the point, glad I saw this as its actualy what Ineed for my setup...
It saves you running stupid preload on the spring if you need to raise the car a bit, unless your shocks have independant height adjustment from the spring preload (my DMS 50mm do not)
as the name of them suggests, id say its so you can set your car up "super lap" spec. then install theese so you can drive home or to the track with your fully super happy race low ride height, without bottoming out on normal roads. and pull them out for some laps etc etc.
    • My first thought is run hardlines, but running a soft pipe is easier and quicker, though normally more exxy...
    • It sounds like the perfect time to do easier tasks like, work out how to pull the headlights fully apart, clean them inside and out, and make them meticulous... Or lose all the clips, f**k up polishing the lenses, and get frustrated with that job while you can't do bigger more fun ones and wind up with no usable headlights...   I mean... What?! 😛
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lipomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, more time to contemplate rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
