ECUTalk Consult LCD V2 Sensor Display / Trip Meter / Time Trials / USB Interface
This item is a blue or green LCD (customised to your choice, see below) plug and play diagnostic display/trip meter for pre-OBDII Nissan cars with the 14 pin grey consult port (see car list below), it can display sensor and trip meter data (see below), read and erase fault codes, perform time trials (e.g. 0-100 km/h), etc, all without the use of a laptop.
For more involved diagnostics/logging, it also has an integrated USB 'consult cable', which can be activated by the USBIF option on the main menu. This allows the display to be hooked up to a laptop and used just like any other consult cable (like in my other items). The display will come with a USB cable (standard USB Type A to Type B cable, like those used with printers). The display is 144mm wide, 48mm high and 33mm deep (buttons protrude 3mm), and weighs around 260g. The display has a hi-temp polycarbonate black matte enclosure. Cable length is approximately 140cm.
The LCD is 20x4 character display with LED backlight. You can chose between a green lcd or a blue/white one. Both coloured screens are in stock, you should indicate the colour you would like in the 'add message to seller' field in checkout, or contact me after purchasing to indicate which you would like. The blue/white display is a 'negative' mode LCD which makes it harder to see in competing light or on an angle than the green LCD (which is easier to see with external light), keep this in mind when deciding on colour.
The blue screen below is showing the main sensor display, and the green screen is showing the trip meter display (see down further for more pictures). Both colour displays have the same functionality. Click for larger picture.
Firmware updates may be available in the future to add additional features (e.g. the display hardware has an onboard buzzer, the most recent firmware added support to use it for audible alerts), and you would be contacted by email if new updates become available.
Once connected and the car is on or running and your display is connected to the 14 pin grey consult port, you can then:
  • View sensor data - such as speed, RPM, battery voltage, economy, injector %, timing, AAC, O2, water temp, air flow and throttle.
  • View trip meter data - such as current/ave speed & fuel economy, trip fuel used, fuel rate (litres/hour), KMs travelled, time elapsed.
  • View/clear error codes - view fauls and the number of times the car has started since the fault was logged
  • Perform time trials - 0-60km/h, 0-100km/h, 0-160km/h, 0-400m (and MPH equivalents if MPH option is set).
  • View peak values - view peak speed, RPM, water temp, injector %, timing, air flow, and throttle for the current trip.
  • Change options - units as km/h or mph (which determines L/100KM or MPG), C or F, TPS V or %, LCD backlight settings, etc
  • Audible Alerts - user definable alerts for RPM, speed, water temp, air flow, injector % and battery voltage (v2.02 firmware)
You will be provided with a CD including a user guide, USB drivers and the following Consult software:
  • ECUTalk (our own software, gauges pictured far below left)
  • OBD Scantech 1.29 Nissan (gauges pictured far below right)
  • Conzult (freeware version, picture furthest below)
  • Calumsult
Suitable for most Nissan car models from 1989-2000 that have the 14 pin grey consult port, which is typically found near or attached to the in-cabin fuse box. It will not work for newer vehicles with the OBDII port (e.g. 350Z). It wont work if you have replaced your ECU with any aftermarket one like PowerFC, Autronic, EMS, etc (but remaps or daughterboards with the original ECU are OK). The common vehicles in Australia that are supported includes (but is not limited to):
  • R32 Skyline (9/89+ only) / R33 Skyline / R34 Skyline
  • C34 Stagea
  • S13/S14/S15 Silvia / 180SX / 200SX / 240SX (SR20/KA24DE engines only, not CA18)
  • Z32 300ZX
  • N14/N15 Pulsar (including GTiR) / N15 Almera
  • B13 NX Couple / NX-R Coupe / NX100 / NX1600 / NX2000
  • B13/B14 Sentra / Sunny
  • P10/P11 Infiniti G20 / Primera (not P11-144, this is OBDII which is not consult compatible)
  • K11 Micra
  • U13 Bluebird
  • GQ/GU Patrol (TB42E, TB45E only, check for port, if you have OBDII plug then adaptor may be available)
  • R50 Pathfinder WX (VG33E, 95-98, other models not tested)
  • G50 Infiniti Q45
  • Y32 Cedric/Cima (VG20/VG30 engines, not RD28)
Note: The display will come with the latest firmware which adds support for TB45E engine and adds a second trip meter screen that records all trips data (the current trip meter screen just records the current trip). It also allows adjustments to fuel and ignition timing if you know what you are doing (use at own risk, read the user guide that comes with the display). There is also a minor change to where sensors are display (temperature is at the start of the second line pushing instant economy and injector duty cycle to right - ignition timing then moves down a row to where temperature was previously).
Sensor Display
v2_sensors.jpgTrip Meter Display
v2_trip.jpgMain Menu
v2_menu.jpgFault Codes
v2_faults.jpgTime Trials
v2_timetrials.jpgTime Trial
v2_timetrial.jpgPeak Values
v2_peakvalues.jpgOptions
v2_options.jpgLCD Options
v2_lcdoptions.jpgUnit Options
This picture shows the front and back of the unit - of course this item is only for one display (just two are used to show front/back in picture).
Pictures of some of the software listed above that can be used with the display in consult cable mode (USBIF from the menu)
  • 6 months later...
sorry to use this thread.. but ive been playing with program and its says you can adjust timg and ari/fuel.. im useing the consult cable.. i cannot find any options to change timing / a/f.. can any one help or point me to a place.. have been searching for hours ;) thanx
    • It's innocent. But sometimes people cannot start their cars or change gears because they have a billion stick-on things getting in the way. Yeah, i'm not a shiny thing kind of guy but I'd definitely give this a go. Food for thought. Thanks
    • I am so glad I've been stepping away from the internet more and more so I don't know what "Just Rolled In" is. And no, I'm not googling it, or clicking any links you lot provide.   Second, Prank, pretty much, that silver stuff, wrap all of one section in a new colour. I recommend NOT using anything glossy, go for matte or flat colours. Current work car I'm driving has so many shiney chrome bits and gloss black bits that at certain points of the day I feel it would be easier to drive blind... So much glare in the eyes!
    • You might as well just vagazzle it, like the dumb bitches on Just Rolled In.
    • I thought not. R32s certainly weren't. R33s definitely could have been, but I thought they had much the same gear in them as the 32s. I could be wrong. I had my r32 converted to R143A before I put the Neo motor (and its R34 compressor) into it. So I didn't even really consider the original refrigerant for the 34's compressor. Seeing as the very idea of "conversion" means that it doesn't really matter anyway. What it would really come down to, in the car in question, is what ports are on the lines and if they are R12 or R143A ports. And the little bit of work required to convert them and clean the system out of the old juice.
