Hi,
Has anyone experienced their VDC turning off while driving ?
This has happened a couple of times to me and will come back on when I stop and restart the car.
Flicking VDC switch doesn't turn it back on while driving.
On the way home tonight it happened again this time showing me the handbrake light aswell, the handbrake was not down, after about 20 min the handbrake light went but VDC remained off, I could tell by the way the car handled and the old yellow 'slip light' never came on. But after I stopped at the servo, VDC came back on and the old slip light was back.
I would really like to know whats going on but don't know who to ask, I have a hunch that it something to do with some kind of sensor problem.
https://www.sau.com.au/forums/topic/318371-vdc-turns-off-while-driving/
It is probably your brake fluid level. Sometimes it looks like it is full, but open it up and it could be near the minimum level, at which point your VDC will start turning off, and sometimes your ABS too.
Thanks alot guys my car is actually due for new brakes next week, Fingers crossed , otherwise I'll try the OBDII cable.
due for brakes???
they didn't do them at compliance?
should have been done. most of them that I witnessed coming through had the brakes and rotors done. some people sidestepped this and I dare say if you looked at your tyres they would bethe age of your car unless you changed them recently.
to answer your original question - get the brakes looked at first.
Mine most certainly weren't done at compliance (pads nor rotors), as my pads are pretty shagged and my rotors are rooted at 60,000km with massive lips. ALL of the V35s I had looked at for sale at dealers in Sydney (that were all fresh imports) had massively lipped rotors, which was at odds at the reported 25,000km or so that each supposedly had.
  • 4 weeks later...
Hi,
Hi Cruzen,
I'm experiencing the exact same thing, been checking the forum all night to see if there's a fix for this issue.
Did you find out what the problem was?
When I got my car back in Oct 08 55k on the clock it had new rubber but the front rotors were rooted as well with massive lips although the rears seemed ok, also my brake fluid was pretty low which would cause the brake warning light to come on during hard braking or if i was going down a super steep hill. Anyhow bought a new pair of slotted rotors for the front and had new pads fitted + new brake fluid and havent had the warning light come on
I had somthing similar happen to me the other day, lost tractions for a second taking off at the lights as there was a slight crest, nothing major just like a half a second loss of tractions any way long story shot, the "VDC off" light and the "Slip" light came on stayed on and wouldnt go away untill i l restarted the car, now iv checked the Break fluid its good, my tyers are near new 90ish tred, but brakes im not to sure on.. any sujestion to why this happens?
and for future refference what Break fluid should i get and where is a good place to pick it up, i live in brisvagus
Cheers.
Cheers.
Hi mate,
I just got Valvoline heavy duty dot 3 from Kmart, was on special at kmart only $5
Hi mate,
I though Dot 4 was standard in our cars and Dot 5 is what people flush the system with because its better. Didn't think that dot 3 would be a great idea.
Not sure. Maybe some of the other guys can verify if its a good idea using Dot 3.
The brake fluid resevoir I have in my car states to use dot 3 that's why I bought it..
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
