Am i the only one that finds this funny?
Surfing SAU whilst tuning!
doing XR6 Turbos.... it takes between 5-7mins for each write. (make a change press enter then .....wait 5-7mins) seriously need someone to release decent LIVE tuning for these fkrs, its no wonder latley that i see the same map loaded in each car... someone locally is obviously too lazy to do it properly...... and they are making a fortune from it as its hardly viable to do it properly like i do.
i need something to stop me going crazy whist waiting hence inter-webs in the background :(.
Any reason why only 17 psi Trent. I know when I ran 15 psi through my 3071 on an SR it was fairly lame......when upped to 22 psi it was another story :rofl:
both cars were @ 90% inj duty...... damn killjoy for sure :P
both like to be around 20-22psi like you say, but these are the only two i have which are apples to apples, i have a few 22psi runs on the T67 (another car) but the GT3071is not complete.
Cars are off getting injectors so when they return i will post em up but i reckon months not days... :P
yeah you can see the L2's unhappy, the 8cm rear is just too small for the 2.5l. To make 300 its running 25psi .... a quick check of the exhaust manifold pressure would tell the story....
runs @ 17psi and i have picked the best average of both. The T67 is a bit wavy but has since been sorted.
just looking over that trent, goin by the colour of the lines... the 3071 which makes less power has a much fattter torque band? or.. are the colours switched around and i'm reading it wrong
hey toffy, I'm not so much a technical guy but when my car was setup i asked for a responsive setup without losing too much top end. Thought i'd share what i have. I was recommended into going with high flowing the stock r34 turbo and getting a garret gt30 core installed. I don't have the full turbo info but can get this info and others if interested. Here is my dyno chart.
3rd gear?
then its useless to use as a comparison unfortunately.
so i'll assume i read that sheet wrong than and the lesser power figure in yellow didnt go with the higher torque figure in yellow on the dyno sheet you posted...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
