the best ones around are from Paul Ruzic (mountainrunner on here). Or a custom setup if you have some genuinely unique requirement like a $500k time attack car.
the local ebay ones are $15 of variable resistors that cost $250....steer clear!
I have no idea about the skylab ones but I would be very surprised if they did even half of what the Ruzic ones do.
Well, I'm a daily-driver seeking for better handling.
A 2wd/4wd swith would be great for doing powerslide on a corner ( yeah, you know, when you want to give a ride to a friend lol..) and for drag purpose.
I might be tempting to learn how to track my gtr.
I have a Ruzic engineering (mountainrunner) one installed, I highly recommend, it only works on corners.
In other words no difference for straight-line purposes, which is why I asked about purpose.
There is a controller for drag-only, but the majority are for modifying how much front wheel torque during corners. I read about the two you mentioned but didn't find much info about them.....
Do you have an R32 GTR or newer?
What are people's thoughts on the Field ETS in comparison?
i have the field ets. found it works great. easily adjustable, forwards and cornering dials. i think it be more suited to track but maybe for drag too.
i did however buy a ruzic unit to install dew to it having more function.
Yes. a R32 GTR 90
The HKS kansai controller is the one that can be used for drag. Other than that and custom made applications like Mark Berry's R34, every other controller bends the signals in the standard ATTESSA computer.
But the effectiveness of those controllers is over a wide range. If you want to go bottom of the market just buy a variable resister from jaycar, don't pay that ebay guy $250 for the same thing.
Well, I don't want to mess with electronic. I did a BEST OFFER on ebay and I won the extremeTSC for 170$ shipped. For a better 4wd traction and a 2wd-4wd switch it's O.K priced.
seriously, why bother putting up a thread asking advice when you have no intention of taking any of it? everyone who posted here told you they were rubbish and gave you better options. duncan even told you how they worked and what they are made from (and he knows as he used to make his own AWD 'modifier') but you had made your mind up before you started the thread and just hoped someone would post up and tell you they are awesome. you just paid $170 for a $4 toggle switch (the AWD/RWD) a 80c fuse, and about $10 worth of variable resistor to alter the signal between g-sensor and attesa ecu, maybe $10 worth of a pretty case to hold the bits.
I don't mean to sound like a prick but it's frustrating when you make a thread and people with knowledge take time to answer your question and you just flatly refuse to listen at all. it's a waste of their time and yours as well.
For everyone's reference I found this page on the GTR canada forums that has pictures of this Skylab TSC.
I bought one of the local ebay ones before this thread was created.. so how effective are they? The comments in this thread are making me query whether its even worth installing.
Most people who bought the Skylab TSC or ebay one think its good, technologically its vastly inferior to a Ruzic controller, that said most people seem to think the Skylab TSC or similar is better than nothing.
If you can get a Ruzic one and have the money then go for it, I did the research and bought one and its great, I haven't played with it much of late in terms of settings but most people who have the Ruzic can attest to the difference it makes. I can't speak for any other controller because I only installed one of course :(
I just hope other people who read the thread will benefit from it. The op has made his choice, I can't see why he chose that particular one though...
yeah I guess the ebay thing is easy, its just that the profit they are making bugs me :(
anyway....every 32 gtr I've ever met needs a controller, even a basic one, so I'm sure he'll be happy with the difference
I like something clean. Where can I buy the cute little box? One time I tried playing with electronic on my car. I end up stalling on the highway! You make it seems like it's a easy job to do. Well, I'm a car detailer, I bet what I think is super easy to buff, you would be scared to burn the paint. Each one has his weakness.
2) All the options mentionned here was MINIMUM 450$. I don't want to put THAT much money on a TSC that I will only use in the street. So, the unit at 150$ seems to be right for me.
Luckily for me, the previous owner had fitted both the HKS EDA and the ETC. Hardest part has been finding any info on these, but this may help this guy understand the ATTESSA http://www.gtr.co.uk/forum/99794-hks-torqu...o-function.html
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
    • Oof. One of my mates has an R34 GT-R that he initially was a "I want to go twins for response and convenience" on his stock 2.6 with Kelford 272 cams, but his friends are pests and were always in his ear about their place being in the bin.   Eventually one of the 2860-5s decided to add it's own input and force his hand, so he conceded and went for a Pulsar 6262G ("G35 900") with T4 0.85 hotside.    Here's an overlay of the results, same cams, same stock bottom end, same boost, same fuel, just from a pretty tidy 2860-5 install to a Pulsar turbo on a 6boost maniifold on BP98.   Worth mentioning here, it may seem like a dead horse thing but the dyno plot doesn't tell the story of how much better it is to drive - transient response has completely changed the car, he used to have flat foot shifting to stop it having to wind up again on gear changes even at >7000rpm... now it builds boost faster than that even short shifting.   It's 100% transformed the car before you even consider how much better it holds on: Pulsar and Garrett aren't the same, but from our experience if you're just looking for a better drive and the ability to make the same or more power I think the divided G30 770 would probably be the smallest I'd go to.
    • Great work Duncan, any events local you will give it a test once all done?
