Hay guys,
Ok so when i bought my car it never had a blow off valve installed, just a blanking plate over the stock bov location.
This is how it was, see the 2 nipples coming out of the intake manifold have been circulated.
I took the top one (the one you can see best) and connected it to my new bov, and just plugged up the bottom one.
Is this correct? is this a vacuum line? what were these lines used for as stock?
and i have taken the car for a drive with the bov in and it sounds exactly the same as it sounded with the blanking plate.
Any help or advise would be greatly appreciated, Thanks guys.
https://www.sau.com.au/forums/topic/318414-rb20-bov-vacuum-question/
how tight is the spring in your new bov? if it is too tight and you are running low boost then you might not have the pressure to open it properly, or it will just flutter as it doesn't have enough pressure to force all the air out in 1 go.
I first tried it at the level it came at, i would say 50% tightness, and then i tightened it up to about 75% but is still exactly the same as when i first put it in and is the same as no bov.
Do you know if that is connected to the right vacuum lines?
Thanks
yes that is a vaccum line. it doesn't matter which vaccum line it is connected to as long as it is a vaccum line.
also making the spring tension tighter will only make the problem worse. that is like trying to push a car and not being able to move it very fast so having someone pull up the hand brake to see if that helps.
loosen the bov off as much as possible and see what that does.
might also be worth checking to make sure that there isn't something inside the hose that is blocking it. take the hose off and try and look through it.
also pull the bov off and make sure you can push the valve up by hand and that it isn't siezed. if it is brand new then there is a possibility that it was shipped with 2 springs in the bov, meaning that it is extremely tight and hard to open and you aren't running enough boost to open it.
Yeh, thanks mate, ill loosen it right off and see how that goes, i dont think it would be the hose as its brand new, but i do remember just mucking around and trying to push the valve open with my hand and it not budging i didnt take much notice at the time as i thought it just didnt work that way, but i will look into it.
Thanks
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
