I bought some injectors for my car but I won't be needing them so they're up for sale.
They are Siemens VDO DEKA 3/4 length 14mm injectors which are a suitable replacement for ER34 RB25NEO engines. Also suit FG F6 Typhoons...
Specifications:
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 52lb/hr = 550 cc/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Connector: Bosch MINIMETER (SAME AS EV1, EV6) (USCAR PLUG ALSO AVAILABLE)
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
They come with the plugs needed to fit them to the RB25 etc
I'm in Perth but will mail wherever!
$500 plz
I'll update with pics later
Edited by [ANGRY13]
https://www.sau.com.au/forums/topic/318435-fs-siemens-550cc-injectors/
