VG30 Highflowed turbo (OP6 rear housing) built by Precision Turbochargers, running t04b internals and is plain bearing. Has done approximately 8000 to 10,000k's in the last 1 and a half years which most of the k's being highway driving. But other then general street/highway duties, this turbo has done 3 drag meets (about 15 runs) and a couple of hours on the dyno.
This turbo on my RB20 was making 300rwhp on 18psi, though on a RB25 I'd expect closer to 350rwhp on 18psi.
This turbo is in great condition, has the same amount of shaft play as when first installed.
Also includes a modified oil line which is need to run this turbo aswell as the banjo bolts on the turbo side for the water in/out.
All thats needed to bolt this turbo on is the elbow and the metal oil drain pipe off an RB25 turbo.
NOTE: Also if required I can supply a R33 RB25 actuator.
Asking $900 + postage.
Located in Ipswich QLD (just outside Brisbane)
Please PM for further info.
https://www.sau.com.au/forums/topic/318451-fs-highflowed-vg30-turbo/
  • 4 weeks later...
  • 4 weeks later...
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
