yeah i know youll say to put this in the WTB section but not everyone looks there and some people may not have decided to sell their cars yet, so i thought id put a little note in here.
So if theres anyone with a 32 or 33 NA wanting to sell it ... in QLD thought ... i would be interested.
Thanks
https://www.sau.com.au/forums/topic/31846-any-na-drivers-wanting-to-sell/
  • 4 months later...
hay man i libe in vic but the cost is not that bad i have a r33 in great condision total stock other then a pod filter and in exsorst cos i dont live in melbourne any more its in storage in a factory
the interor has been dune
Car: R33 Gun metal gray
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
