Item Summary: Nissan Skyline R33 GTS-t Series 2 Turbo Manual, 90,000k
Condition: Excellent
Asking Price: $14,500 ONO with 12 months reg and roadworthy
Contact Info: Leon: 0400 001 198
Specs:
Trust Greddy TD05 10cm housing, makes approx 265rwkw @ 16psi
Greddy intercooler kit
Full exhaust from turbo dump to tip
Splitfire coil packs
Vipec computer (tuned by Trent @ Status/Chequered Tuning)
Greddy Profec-B Spec II boost controller
Pioneer CD/MP3 Headunit
Kenwood splits front and rear
12" Kenwwod subwoofer and 4 channel amp
Drift water temp and boost gauges, pillar mounted
18" PIAA rims
Car lowered on unknown jap suspension
Bought the car stock about 2 years ago, car is kept in very good condition, serviced every 5K with Motul oil.
I'm selling the car to put money into other car projects.
https://www.sau.com.au/forums/topic/318473-1996-r33-gts-t-series-2/
I have a 180 track car (complied so can be street registered)
But it needs to put together and painted.
http://www.nissansilvia.com/forums/index.p...p;#entry5379973
i already have a skyline though, but in case you find a buyer, you can buy mine :)
sure ur not interested in a nissan bluebird U13 attesa ( 4wd sedan with an sr20det) :)
lol
definately one of the better looking skylines up for sale!!
Edited by deprived777
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
